Asa Cam Results
110 Lobe Sep. Also Put 918 Springs And Manley Pushrods In. With Ls1 Edit Tune And Cutout Open In The I Pipe
Car Put Down 370hp And 366ft Lbs Torque On A Dyno Jet. All Mods In Sig. Still Running Through The Cats. Tuner Said That If I Took The Cats Off It Should Make 15 To 20 More Hp Because The Cam Has A Tight Lobe Seperation And A Large Exhaust Duration. I Still Need To Get A Ported Throttle Body And Underdrive Pulley. Im Hoping For 400hp. Any Suggestions Or Thoughts On This Would Be Appreciated.
if you can i'd love to see a dyno graph. i've never seen an asa cammed graph and am curious what the curve looks like.
once again, congrats, and enjoy the new power
NO FLY CUTTING WAS REQUIRED. THE CAR SOUNDS AWESOME!!!! CAMS LIKE CRAZY
BUT VERY STREETABLE. Trending Topics
With a set of GMPP LS6 heads, and 1.8 rockers I am willing to bet that setup will make 440 RWHP and the best TQ curve ever to be seen on a 346 ci motor..
It's a GMPP cam used for the ASA Stock car series race setups (oh so I think).
The low lift is identical to the regular, GMPP Hotcam (.525), but the ASA has longer duration and is tighter (110 vs 112).
It's a relatively odd cam by today's standards of lift, but it's proven itself over and over to be a torque cam, and a great option for those seeking long spring life.
It wasn't too popular before, when cam choices were more limited due to people not being able to tune it properly for street use, but I think given today's tuning, it can run no problem.
Yes, please, free up that exhaust and redyno!
