423rwhp/405rwtq cam-only A4 w/ MWC 9"...with graph!
Pretty damn good. So this bolt on list got you to run 11.9?
98mm FTP lid
85mm maf
NW92mm tb
FAST 90 intake (Ported by Cartek)
BBK 1 3/4 headers with 3"-4" flowmaster Y-pipe and 4" Vibrant muffler
SLP Pulley
SVO 30lb injectors
FLT Level IV 4L60E w/ Circle-D 4000 converter
MWC 9" 3.89s
98mm FTP lid
85mm maf
NW92mm tb
SLP Pulley
SVO 30lb injectors
MWC 9" 3.89s
Attachment 393837
Here's the graph. It's still stock compression with stock 241 heads shifting at 6400.
Super Hulk Smash
Yeah. Spin uses the XFI/XE-R combo. I actually talked to him before ordering the EPS/LXL lobed cam seen here, except I did get mine pretty much as Spin spec's his on a 114+2. Power should be more or less the same, except a bit more valve control out of the EPS/LXL lobes.
#33
Attachment 393837
#34
Yeah thats more power than my heads/cammed ls1 made with an m6 through a 10 bolt.
#37
He trapped 119 and hit the limiter so it's possible on a good 2-3 that his MPH could be right where you said it should be. Hopefully his new track times go perfectly so we can see if this dyno is happy or true.
Either way cam only running 11.3 is better than most, myself included.
