Found My Long Lost Dyno Sheet!
With an aftermarket airbox, Random Tech Catback system/stock cats, and a cutout, the SS managed 330.9 RWHP and 335.4 TQ.
After the installation of the T-1 cam, the numbers were 338.5 RWHP and 338.4 TQ: no tuning has ever been done to the car.
I am pretty excited because I now have a good baseline before adding heads etc.
Cheers,
Q
I will probably be changing the cam out in the near future anyway..
Cheers,
Q
Now looking at some heads, 2.5 5.3L, from Texas Speed and maybe even a cam swap. I also ordered a LS6 Intake along with a Shaner L3 ported TB.. Hopefully, I can get some more hp after these mods along with a tune.
Q
I feel like
for not getting a good tune but it will happen soon enough
Q
Thanks! I am looking forward to digging around under the hood.
The T-1 Cam specs were: 221/221 .558/.558 112 LSA The powerband is from 1800 to 5000 or so then the torque starts dropping off.. Great midrange
Along with the LS6 intake, I also have a -25% under drive that is going on this week. That should be good for some more power.
Q
Probably for another post/topic but any idea regarding what pump to upgrade to and how much something like that would cost? This would have to be a drop the tank kind of ordeal correct? It is probably a good idea to take care of little things like that as a reliability measure.
Cheers,
Q
( did the " trap door " install) at the time the dealer as 1125 for OE install parts- labor
Try ebay 219.
Camaro/Firebird LS1 V8 Racetronix 255L/Hr Fuel Pump Kit w/ Harness
good luck Johnny
After a few months I had to install a new fuel pump as well.
Cheers,
Q
try this link, easy job, be carefull of the Oil pres. switch, I pulled my intale 3-4 times with no problem, But on the last pull I broke the switch ( about 40-50.00)
you mat buy a special wrench to remove/install the switch or be very carefull when moving the vac line which goes to brake boster, also becarefull with the 3 ? vac lines which connect to the REAR of intake
you may like to change both knock sensors and the wireing horness while you have the intake off, do not over tighten them and do not pinch the wires which connect the knoch sensors
good luck Johnny
read this
http://www.ls1howto.com/index.php?article=5
