Brian Tooley cam, stock LS1 241s, FAST 90/90, TH400, 9" - 420 RWHP
Old 01-02-2014, 11:30 PM
01_ram-air's Avatar
Here's an update for you:
(The car has met my expectations)
Old 01-03-2014, 12:41 AM
Baconz28's Avatar
Holy smokes!!! IM anxious to see what my Brian tooley cam go do in my iron 6.2 and rectangle heads
Old 01-03-2014, 06:49 AM
Brian Tooley Racing's Avatar
Nice work! Congrats to you, Formato at Fasterproms and Kyle at Fat Body Performance! That's getting it done if you ask me, especially with a cam that you could drive daily.
Old 01-05-2014, 06:59 PM
01_ram-air's Avatar
Thank you for building a badass cam profile. It flat out gets it done. I have no driveability issues. I could easily daily drive this car if I wanted to.
Old 01-05-2014, 07:00 PM
01_ram-air's Avatar
A couple videos from yesterday
1/8 mile bracket cars make you look good on the big end. Got worked on the tree though. Ouch
Looks pretty slow for a 1.45 60'
Old 01-05-2014, 08:37 PM
BAIN's Avatar
Originally Posted by Martin@Tick
Very nice!
FWIW my old cam only set-up with a 4800 stall, 275/60 drag radials@18psi, TH400, 12 bolt with 4.10's, Fast 92/96 and239/247 .624"/.624" 110+0 camshaft made 424/383 on a Dyno Jet.
Ran 10.20's@129mph at 3000lbs race weight in 1800-2200 DA. Yours should run very well.
Not to take away from this thread, but I want mor info on this. The cam only list says 10.5. I have searched, but can't find any info on the pass
Old 01-06-2014, 01:19 PM
93camaro_zzz's Avatar
So just to get everything straight, the 10.20 you ran, that was on the 150 shot?
Old 01-07-2014, 01:20 AM
01_ram-air's Avatar
My 10.25 was on the 150 shot
Old 01-07-2014, 06:02 AM
Captain Double Post
BOBS99SS's Avatar
tooley is the man!
Old 01-22-2014, 09:12 PM
LilJayV10's Avatar
Originally Posted by JakeFusion™
That's an excellent cam.
I'm very interested in this cam. I'm worried about what the low end torque would be like though using stock heads.
Old 01-23-2014, 08:59 AM
The Stg IV cam seems to have great low end torque due to the chosen IVC. Guys can get their cars to run at 1100-1200 rpm in 6th gear with no bucking.
Old 01-23-2014, 10:23 AM
  #32
Baconz28's Avatar
Bob is right. Tooley is the man.
Old 01-24-2014, 08:26 AM
  #33
ezzlez28's Avatar
I had no problem cruising in 6th at 1100 rpm. Really looking forward to seeing what my new exhaust set-up brings power wise and glad to see how it likes nitrous with the OPs set-up as well.
Old 01-24-2014, 07:23 PM
  #34
LilJayV10's Avatar
Hopefully more people with results will post up. Not just in here, don't want to completely highjack the OP's thread. LOL
Old 03-20-2014, 09:12 PM
  #35
01_ram-air's Avatar
Went up to a 73 jet on the nitrous:
10.01 @ 134 pass
10.05 @ 134 pass
Talked a lot of smack with this Cobra over the past couple months. We finally got to line them up.
Old 03-20-2014, 09:25 PM
  #36
adamantium's Avatar
Nice! Whats it trap on motor?
Old 03-21-2014, 10:08 AM
  #37
Rise of the Phoenix's Avatar
Knocking on 9's. Damn impressive.
Old 03-26-2014, 08:46 PM
  #38
badblazeSS's Avatar
very nice
Old 03-27-2014, 02:47 AM
  #39
01_ram-air's Avatar
I haven't spent much time making N/A passes, but it's trapped 118
Old 03-27-2014, 03:39 PM
  #40
01 ram-air, do you remember the piston to valve clearance you had? Your 241 heads are stock, non milled, correct. Trying to see if a cam this size would clear my setup. Current cam is 227/235 110 LSA and I've currently got .069" intake clearance and .101" exhaust clearance.
Quick Reply: Brian Tooley cam, stock LS1 241s, FAST 90/90, TH400, 9" - 420 RWHP
