Dyno'd my bolt-on car
Old Jul 18, 2013 | 01:21 PM
ChrisSingh90's Avatar
Default Dyno'd my bolt-on car
Local place had a dyno day, for $50 I really couldn't complain! Anyways it put down 330 whp and 355wtq. On the next two runs it made 375 wtq and then 365 wtq, definitely thought that was strange but it looked like spikes in the beginning of the dyno graph? Any idea on the torque discrepancies?
Anyways the car has ARH 1 7/8" longtubes, 3" high flow-catted Y-pipe, SLP loudmouth axle back, POTZ ported TB and MAF ends, SLP lid and smooth bellow.
It's still on factory tune, how much do you guys think it will pick up with a tune? My plan is to do an ASP underdrive pulley and 4.10 gears, then get it tuned when all the bolt-ons are done. Anyways, here's the sheet.
Chris,
Old Jul 18, 2013 | 04:18 PM
HCI2000SS's Avatar
Your torque number is unusually high compared to horsepower. A tune should give at least 10 hp i'd hope
Old Jul 18, 2013 | 07:18 PM
Blackpanther99's Avatar
Looks reasonable
Old Jul 18, 2013 | 07:33 PM
1BAD98LS1's Avatar
Should put down at least 350whp with a tune and pulley, helps its a 6 speed too
Old Jul 19, 2013 | 09:34 AM
Gabbiani's Avatar
On that dyno your really made around 335tq. Look at the graphy. The hump at the beginning was caused by the operator.
Good start. Tune is always good. Better yet buy the cable and learn yourself. Will be much more rewarding in the long run.
Old Jul 19, 2013 | 10:38 AM
MikeWS6's Avatar
330/355 is pretty good for a bolt on car. The torque is probably a bit high.
Old Jul 19, 2013 | 11:50 AM
Thanks, yea you're right. Not bad at all I guess. Does that HP and TQ sound about right given the mods? What did the operator do exactly to cause that spike? I'm curious.
I do know how to tune, just not familiar with LS1's. I tuned my E85 supercharged GTP into the 11's. The problem is I'm only familiar with that platform, so I just need to do some research and see what kinda AFR and Timing N/A LS1's like. I'm used to tuning supercharged V6's, but N/A tuning is supposed to be easier from what I hear? I just need to save up and buy HPTuners and a wideband and start playing with it.
I had a PowerTuner with the GTP. It's pretty much the same thing but the PowerTuner has way more tables available than HPTuners does for GTP's, and it's alot cheaper which is why I chose that one instead.
Chris,
Old Jul 19, 2013 | 03:31 PM
Gabbiani's Avatar
I would say you are in the right ball park for power on a Mustang. Would be a bit higher on a dynojet.
All of my tuning experience has been on other dynos. I'm guessing maybe the load cell doesn't kick in until they start sampling the run so it absorbed some inertia from the drivetrain? That probably makes no sense but it would take something similar to popping the clutch while already going 60mph - basically a shock to the driveline.
Old Jul 29, 2013 | 08:59 PM
GuatoLT1's Avatar
Is this in STD or SAE?
Old Aug 13, 2013 | 08:32 AM
JDMC5's Avatar
I tuned a 00 SS M6 the other day that had stainless works headers, slp catback, slp lid with egr delete and it picked up 20 rwhp on our mustang dyno for a total of 344hp at the wheels.
Old Aug 13, 2013 | 09:46 AM
Nice! Makes me want to get my underdrive crank pulley and a tune ASAP! It was SAE if I recall correctly.
Chris,
Old Aug 16, 2013 | 04:13 PM
klutchkaaa's Avatar
not bad
Old Sep 3, 2013 | 01:01 PM
rkdc5z06's Avatar
flat tq are good god dd
Old Sep 3, 2013 | 01:02 PM
rkdc5z06's Avatar
50 was good price too!
Old Oct 2, 2013 | 03:16 PM
karpetcm's Avatar
My 01 Z dynoed with almost full bolt ons 350/355. So your right there with tune. As long as it drives good and your happy that's all that counts
Old Oct 2, 2013 | 03:53 PM
Blownbayou's Avatar
See sig..... Tune will get you there
Old Dec 13, 2013 | 03:37 PM
Sweet. Got the ASP underdrive installed. Once I do the 4.10's I'll but HPtuners and a wideband and get this bitch tuned!
Chris,
Old Dec 13, 2013 | 05:40 PM
11SECSS's Avatar
I would say you will pick up 15-25 hp with tuning and the other mods
Old Jan 11, 2014 | 09:40 PM
Firebirdmuscle's Avatar
Very nice. Makes me want to see where I'm at with mine.
