Stock Bottom End Ls2 NA...WHP Results?!?!
My C5 Zo6 has a Ls2 short block w........
-Vengeance Racing VRX5 Custom Grind (236/238 .601/.605 113 LSA)
-Stock 243s
-Ls6 Intake
-Kooks Long Tubes
-Kooks Off Rd X-Pipe (No Cats)
-Stock Rockers w Truion Upgrade
-T56 Car
Dyno Tuned out @ 421WHP 400WTQ......(Dyno Jet)
Now w a set of TEA stage 2 243's whats the HP gain ya think Im looking at w them CNC Porting my heads and bumping the CR up to the most I can w Pump Gas?
Also would I be leaving Power on the table keeping my Cam or swap it out at the same time as well?
-Stock 243s
-Ls6 Intake
-Kooks Long Tubes
-T56 Car
The power it makes now. There is no guarantee you'll pick up 40 with heads either. You should really be in the 440 range I think. Maybe it will take messaging some of your parts.....maybe it will take changing a few parts.
Well one thing about the set up is the Ls2 knocks w my Ls1 pcm dont give us a reading so there could be some timing left to be added but w out a darn KR reading while tuning we left it safe.....
While the heads come off or before I plan on making sure the Knock sensors are reading correctly so when we re tune the car for the heads I can lean on it for sure w out having a issue of Spark Knock
Not that dynos really matter, but for reference my buddy made around 420 rwhp on his cammed 06 GTO with a stock LS2 intake with full exhaust, 6-speed and tune, so this seems about average to me. It was on a Dynojet dyno as well
Thinking w a .040 Head Gasket at 63cc Cambers and if the pistons come out of the block by .010 (Which I will Measure once the Heads come off) I will be at 11.78:1 CR
Kinda of worried about the .030 Quench is that to tight? on a stock bottom end Ls2?
I think the power is about right. Cam is not gigantic - it is still 243s and an ls6 intake. Fast would get you 5-10. Good heads would get 30-40.
I've done tons of c5 z06 cam only cars in the 410-430 range depending on cam size.
The extra .3 liters isn't that big of a difference.
I would agree if it was a cam only ls1. But a ls2 with ls6 heads and a decent size cam should do better. Unless average is your goal.
Like I said op.....go over your parts...message them where needed and maybe change a few and tune it again. I think there is some left in it.
Go back up to Post #7
Just as an insite, buddy had a 05 gto, pacesetter headers, catless with borla catback, and a vararam. Put down 434/418 on E85. Untouched everything internally sans cam. Car runs like it to. I put down 454/425 on the same day in my LS2 and on a perfectly even hit I was a slow but steady pull away.
His graph for reference.
Alright ppl.....the point of this Post was not to bash my Whp..........fact of the matter is it's a light weight Zo6 that as it sits pulls away from a 475whp F-Body w my "little" 420whp
All I wanted to see was the Gains I was looking to make, thats all
