What would dyno #'s be if SAE corrected?
Old May 3, 2004 | 06:37 PM
WhitePheonix's Avatar
Default What would dyno #'s be if SAE corrected?
I had my car dynoed on a dynojet a couple of weekends ago. I have a Magnaflow exhaust, SSRA2, and TSP lid. My best run was 328 hp, 342 tq. I was really happy with these numbers until I realized they were uncorrected/standard numbers. What do you think my numbers would have been if they were SAE corrected? And does that seem normal with the mods I have done?
Old May 3, 2004 | 07:39 PM
mikey's Avatar
LS1TECH Sponsor
There is no way to accurately tell you what the SAE number would be. Can you contact the dyno operator and get him to tell you? It's just a simple conversion for WINPEP (dynojet software).
Mike
Old May 3, 2004 | 08:40 PM
Is parasitic driveline loss 15% for uncorrected and 20% for corrected?
Old May 3, 2004 | 08:56 PM
2xLS1's Avatar
SAE corrected numbers have nothing to do with driveline loss. It has to do with atmospheric conditions at the time of the dyno. Air temp, humidity, and barobetric pressure. Correction factors are usually somewhere between .95 and 1.05 that your numbers are multiplied by. Your files should be stored on the PC where the dyno is along with the wearher data when you dynoed. Only they can give you the SAE corrected numbers.
Old May 3, 2004 | 08:57 PM
ok cool, I appreciate the info!
Old May 3, 2004 | 09:44 PM
I know this is a useless question, but on the premise of bragging rights. To figure out flywheel horsepower I came up with 385 hp and 400tq with my uncorrected rw #'s. If driveline loss has nothing to do with SAE and STD #'s. Would my flywheel hp be less if I used SAE #'s as opposed to STD. Im trying to get a better understand of SAE/STD#'s in relation to flywheel #'s. Again, absolutely pointless in real world terms but solely for bragging rights.
Old May 3, 2004 | 10:11 PM
2xLS1's Avatar
Again your SAE #s could be higher or lower than your STD #s depending on if the weather was more or less favorable than what SAE considers ideal when you dynoed. Reread what I posted about there being a correction factor that your #s are multiplied by. For example, if you dynoed when the atmospheric conditions were exactly what SAE considers the standard, your correction factor would be 1.0.
Old May 4, 2004 | 02:54 PM
WAHUSKER's Avatar
But whatever the #s are, most people figure at least 15% driveline loss on a stick, & 20% on an automatic. For instance my 370rwhp is roughly equal to 450fwhp.
Old May 4, 2004 | 08:41 PM
Absolute barometric pressure:28.85 in.HG
Intake Air temperature:70.9
correction factor:1.04 STD
vapor pressure:0.32 in.HG
SAE#'s require
Absolute barometric pressure:29.23 in.HG
Intake Air temperature:77
vapor pressure:0 in.HG
This is interesting because even though my temp. was lower, so was the pressure, so I wonder how far off my numbers are from corrected. I will call the dyno shop tomarrow for the exact figures though.
Old May 5, 2004 | 06:31 AM
Plum Crazy Rob's Avatar
Lightbulb
Quick clarification:
"STD" and "uncorrected" are two DIFFERENT things. STD refers to ISO Standard conditions, 59F and 29.92 absolute baro (we in KS jealously call that "Houston" - on a bad day ).
Uncorrected are purely observed numbers under whatever condition you dynoed in. If you dynoed when it was -459 F degrees, you are going to have some hellaciously high numbers reported
