799 Heads and Cam - Results
Old Sep 20, 2013 | 03:30 PM
98ws6blk's Avatar
Default 799 Heads and Cam - Results
Just got the dyno results from my Head/Cam swap. This is my first dyno, so I don't have any before and after. Major mods in my signature.
Before anyone flames me, I know these numbers seem way too high for this combo. I assume a happy dyno, but it's just a tuning tool anyway.
I did some minor diy porting to my heads: blend seats, smooth rocker bump and got a competition valve job. I milled them 0.025 and used a 0.040 gasket, so it has a lot of compression (aprox. 11.5).
Big thanks to Martin Smallwood! (tick performance) for the custom cam. I'll keep the specs quiet ; )
Old Sep 20, 2013 | 04:44 PM
Kingc8r's Avatar
Nice numbers.
Old Sep 20, 2013 | 04:49 PM
thunderstruck507's Avatar
Love the torque curve! Numbers definitely seem high for home port heads but who cares
Why the secret on the specs, usually he's pretty open about that kinda of thing?
Old Sep 20, 2013 | 04:51 PM
98ws6blk's Avatar
No real secret on the cam. Basically a SNS stage 2 just tweaked a little to match my high compression.
Old Sep 20, 2013 | 04:54 PM
HCI2000SS's Avatar
Very nice! Now it's time to run it at the track, and see if the dyno numbers match the trap speeds
Old Sep 20, 2013 | 05:06 PM
30th t/a's Avatar
Yea the numbers are extremely inflated. Those types dyno's seem to always give out very generous results.
Old Sep 20, 2013 | 05:25 PM
98ws6blk's Avatar
How can you tell what type of dyno it is?....I'm not sure myself.
Old Sep 21, 2013 | 08:01 AM
firefighter813x's Avatar
This is what LS1's make with a LS6 intake now??? Seems high...
Old Sep 21, 2013 | 12:09 PM
98ws6blk's Avatar
Outside of my high numbers, does my dyno chart look about right in terms of where the HP/TQ sits relative to RPM?
Old Sep 21, 2013 | 01:47 PM
HCI2000SS's Avatar
Yes, that looks totally normal to me. Just a FYI here, back when I has my old LS1 setup I made 405 rwhp on one dyno, and 460 rwhp on another, and guess what... both were Dynojet dynos to boot lol. I think you can see my point lol
Old Sep 21, 2013 | 02:39 PM
98ws6blk's Avatar
Cool. Thanks! Yeah, I just want to make sure everything is normal : )
Old Sep 22, 2013 | 09:22 PM
manfred717's Avatar
Nice smooth graph, now take it to the track and see what she does!
Old Sep 22, 2013 | 09:59 PM
danger ds's Avatar
Would like to see some track time, congrats on the setup.
Old Sep 23, 2013 | 08:58 AM
30th t/a's Avatar
I'm not sure what kind of dyno that is. Yes I think your HP & TQ graph looks inline with the RPM.
Here are two examples that I found both showing extremely inflated torque numbers and HP numbers using the same type of dyno that you used. I know a dyno is for tuning but I also like to know what kind of power Im putting to the ground and I would like that number to be accurate.
https://ls1tech.com/forums/forced-in...ers-today.html
https://ls1tech.com/forums/dynamomet...cam-guess.html
Old Sep 23, 2013 | 10:00 AM
98ws6blk's Avatar
[QUOTE=30th t/a;17703950]I'm not sure what kind of dyno that is. Yes I think your HP & TQ graph looks inline with the RPM.
Thanks man. So you are guessing these are the same dyno types based on the similar look to the software interface in the picture I guess...
Old Sep 23, 2013 | 03:35 PM
30th t/a's Avatar
That and how they all have very inflated numbers. 470rwhp 462rwtq is what a strong 383 stroker or even a mild 402/408cid would put down.
I'm sure your car runs strong though. Should definately get you in the 11s if you hook up.
Old Sep 23, 2013 | 04:31 PM
KCS's Avatar
KCS
Moderator
The 460ft-lbs of torque is pretty high for a 346ci engine on pump gas, but as you said, its just a tool. A before and after would have been good to see.
Old Sep 24, 2013 | 10:11 AM
Sales@Tick's Avatar
It's a custom SNS Stage 2 cam. Valve events are identical.
I would expect this set-up to make 420/390-440/410.
Old Sep 24, 2013 | 12:35 PM
Rise of the Phoenix's Avatar
Two things that get people more worked up than anything are:
1) politics
2) dyno numbers
