SBC 406 Dyno Predictions
Old Nov 19, 2013 | 11:21 PM
Fast 95 Z28's Avatar
Default SBC 406 Dyno Predictions
Not sure if I should have posted this in the SBC section or not, but here it is.
So, I'm building a sbc 406. I'm looking to get 425 hp/500 ft.lbs of torque out of it. Revving to 5500-6000 MAX, maybe only 5500. I believe I will achieve that with these parts... tell me what you think
4.155" bore (.030) over
3.75" stroke
Speedpro +12.5cc dish pistons
Stock 5.565 chevy 400 rods
Eagle Cast steel crank
Stock Vortec heads 062 casting (64cc chambers)
Vortec Edelbrock Performer RPM Air Gap
Assuming .052-.065" quench depending on how far down the piston is
LS3 springs with Comp cam 787 retainers
Holley 750 double pumper
1 5/8" Long tube headers
Howards Cam:
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:2,000-6,400
Intake Duration at 050 inch Lift:231
Exhaust Duration at 050 inch Lift:241
Duration at 050 inch Lift:231 int./241 exh.
Advertised Intake Duration:285
Advertised Exhaust Duration:295
Advertised Duration:285 int./295 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.470 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.470 in.
Valve Lift with Factory Rocker Arm Ratio:0.470 int./0.470 exh.
Lobe Separation (degrees):108
Camshaft Gear Attachment:3-bolt
Running 91 octane gas.
Static Compression will be 10.1:1 - 10.5:1
Dynamic Compression will be 7.81:1-8.03:1
Its going in a 69 camaro with a muncie 4 speed and 3.08 rear gear (for now). I'm hoping for killer low-midrange torque.
Old Nov 20, 2013 | 03:37 AM
Abdullah's Avatar
nice engine and a nice car .
where did you get the 69 Camaro from? for how much?
what engine, transmission and rear end does it have?
is it in a good condition?
thanks.
Old Nov 20, 2013 | 11:20 AM
thanks.
I said above its a muncie 4 speed with 3.08 rear gears.
Old Nov 20, 2013 | 12:36 PM
1989GTA's Avatar
"I'm looking to get 425 hp/500 ft.lbs of torque out of it."
Is that on a chasis dyno or an engine dyno?
Old Nov 20, 2013 | 02:11 PM
That would be an engine dyno, my goal is 425 FLYWHEEL horsepower.
Old Nov 20, 2013 | 04:21 PM
H8R's Avatar
H8R
You're probably close to that. The Vortec heads might not get it done.
Old Nov 20, 2013 | 04:40 PM
Cosmik de Bris's Avatar
I think you'll get to your goal with that setup. That cam is quite mild for a 400.
Old Nov 21, 2013 | 01:15 AM
Yea I wanted a milder cam since its a street car and I wanted more engine vacuum. I chose a 108 LSA because I wanted more of a choppy idle and figured I'm only revving 5500rpm so the extra low end torque would be nice.
Old Nov 21, 2013 | 11:53 AM
1989GTA's Avatar
I agree. You should be able to achieve your goals.
Old Dec 6, 2013 | 11:11 AM
So I just found out today that my pistons are .022" down the hole. So with a fel pro headgasket at .039" this puts my finally compression ratio at 10.24:1, and my DCR at 7.87:1. The quench isn't ideal at .061", but I figure with my vortec heads I can get away with running 91 octane on this engine without it pinging. What do you guys think?
Old Dec 9, 2013 | 08:17 PM
A.R. Shale Targa's Avatar
Tightening up the quench makes an engine less octane sensitive. I'd for sure
try to find a 4.160" Cometic or Fel Pro MLS head gasket that measures .027"
for a still less than ideal but much better .049" quench. BTW those heads
won't need any more than 32 degrees of total timing advance.
Old Dec 11, 2013 | 09:35 AM
DSRE's Avatar
390-410hp at 5200rpm 475-485tq @ 4400rpm
Old Dec 11, 2013 | 01:17 PM
87silverbullet's Avatar
http://www.carcraft.com/techarticles...l_block_chevy/
http://www.chevyhiperformance.com/te..._engine_build/
Old Dec 20, 2013 | 01:18 PM
speer13's Avatar
I think the torque will be there but the power may be a little tuff to get to .... I had a 406 with similar parts, major differance was I had a single plane intake and Iron eagle heads it only made 310 at the wheels....
A few things I see the headers, cam and heads will keep you from making the power...but you are creating quite the torque monster...
As for the article theres a lot to consider they were using the large port bowtie heads which are considerably larger than a standard vortec although both will flow better on the 4.155 bore. They used a larger cam with 1.6 rockers and used a better rod/piston combonation with good balancing and a fairly large spacer and add that they dynoed with no alternator and electric pump.... and neted 466
I would say you will be more than likely in the neiborhood of 375 flywheel ~ 300 at the wheel with the muncie
