LS3 in a 4th Gen Camaro Numbers
If I can run ET 12.03, 60' 1.96, 117.93 MPH with 3646 lbs car with dirver, running 300 treadwear street tires, 2800 stall converter, 3.55 rear gear, automatic trans with LS3 Hot Cam making only 360 RWHP and 329 RWTQ, you should be able to run 10's with those numbers. Dynojet HP number is 409 on same setup.
Now I have to say, my numbers are low because I'm running LS2 MAF, with 3.0" stepped to 3.5" to 4.0" air intake system that starving the engine for air. I'm in the process of correcting that problem in hopes I can get car to run solid mid to low 11's with 60' still in the 1.9 sec range with street tires.
As ran
New numbers with just LS2 MAF changed to LS3 style. You can see I still have problem due to lack of intake air. HP & TQ are the same on both graphs at 5225 where HP TQ cross. Note that runs were not made on same dyno are on same date, SAE corrected show them to b same requardless of different conditions.
You can see my built in problem in this picture.
Now all that said, I'm puzzled by Dyno Sheet you posted. Never seen a Mustang Graph printed out like that. Mustang wants people to know runs were done on their dynos.
Your numbers are better than most will ever see. Less than normal driveline powertrain lost. HP & TQ lines almost same as GM engine dyno sheet. Shop could do a Power Pull with car setup and give you a very close idea on 1/4 numbers, plus or minus what ever your 60' time is from 1.5 60' time used a baseline for pull.
480 HP - 427 HP = 53 HP lost. 470 TQ - 427 TQ - 43 TQ lost.
fwiw i did 490/418 on their dyno
-brandon
