5.3+TC78 results
Car 93 Z28
Engine 180k 5.3 jy opened top ring gap, 241 heads ls6 intake ls6 cam& springs
Transmission, t56 ls7 clutch
Turbo, TC78 .96 AR flipped truck manifolds 2.5 crossover, 3" downpipe to a flow master with a cutout in front of the rear tire
Fuel, mix 70% 91 octane 30%e85
1st run 10 psi cutout closed
2nd run 12 psi cutout open
3rd run 19 psi cutout open
Why do you think I'm picking up that much tq on the 3rd run but not that much hp?
Props for a solid 5.3L build. Lots of folks in my area doing this. $500 motor, regap rings, clean up pistons, use stock heads or 317s with an LS6 cam or small duration 220s cam, select turbo...profit.
Folks are seeing 550-600whp on low boost (10-14psi) and 800-850whp on 18-22psi, and the motors are LIVING under it. Blows my mind.
