502rwhp/437rwtq 347 c.i. AFR 205/Fast92/TSP 1x7/8"
#89
I may have missed it in all of the posts but was it necessary to fly cut with this combination? I'm still looking for a H/C set-up but will be leaving the stock short block in and don't wish to fly cut.
Scott
Scott
#90
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Car recently hit the dyno with the intake combo, TH400, and 4500 Stall
https://www.facebook.com/video.php?v...type=2&theater
#91
Yea the pulls ranged from 454 to 462. The last pull was 462. Before weather correction the numbers were 480's to 490's then of course with the correction factor they came down with the cold shop.
Every pull peaked around 6,950 and carried very well as you can see.
Main difference from the last dyno session and now was....
Larger weather correction
26" street tire to 26" DR on the dyno
Intake change over
4l60E with 3600 stall to TH400 with 4500 stall
Intake change over
#97
The car has already been mid 10's N/A.
Car has been 9.70's on a 100 shot.
Goal is low 9's possibly even high 8's(I'm sure Shane and Samsel both are thinking WHAT?!?!?) on 200-250hp of nitrous and low low 10's on motor.
With the new trans higher first gear, it will have a more effective starting line ratio making it easier to launch the car. Not to mention the Super Victor killing some torque off the line as well which will really help it launch more consistently and bring the power in faster.
I really think if the car can cut a high 1.28-1.29 60' it will go 8.99999@149-150mph. My old nitrous combo with a 4.10 rear gear(this car has 3.73's) and TH400 would cut a 1.28 60' leaving on a .93 jet with a tenth of a second delay. Both cars are similar in weight as well.
With a better starting line ratio than I had, and a Mickey Thompson Pro Tire(I had Hoosier 275's) this car will do it if they work at it enough.
#100
