LS3 416 Pat G TEA TFS
Old 08-05-2014, 09:44 PM
CUR4VNM's Avatar
Default LS3 416 Pat G TEA TFS
I have a
Ls3 416 11.7:1 comp
TEA TFS235's
Pat G custom cam 248/252
Mammofied FAST102/102
ARH 1 7/8" LT's with synergy custom true duals with magnaflow race bullets
Moser 9" w/4.10's
6 Speed
exedy triple disk
Built and Tuned by Rick @synergy motorsports
Brand new motor.... got tuned after break in time on the dyno and oil change
The following users liked this post:
Stang2Goat (11-13-2023)
Old 08-05-2014, 10:02 PM
CUR4VNM's Avatar
Old 08-06-2014, 03:06 AM
Jimbo1367's Avatar
Are they TFS 245s or 235s?
Old 08-06-2014, 06:49 AM
ctd
ctd's Avatar
What are you running for street tires
It's a beast
Old 08-06-2014, 07:04 AM
TrentSS's Avatar
Good grief...a 416 putting down 587/530 to the rear tires with 4:10's. Congrats man, that's some serious power!
Old 08-06-2014, 07:19 AM
Blackpanther99's Avatar
Beast.
Old 08-06-2014, 10:21 AM
deerslayinrednek's Avatar
Get that thing on the track so we can see some track times
That's what I wanted to build, with 13:1cr and a single plane intake.....but I ended up with a 408
Old 08-06-2014, 11:36 AM
Bill00Formula's Avatar
I'm curious about the heads too. Did you sell the 235s or modify? I have a 427 w/ TFS 235s and only dynoed 533.
Old 08-06-2014, 12:08 PM
Rise of the Phoenix's Avatar
That big of a bore is begging for some LS3 or LS7 heads.
Old 08-06-2014, 02:23 PM
Kingc8r's Avatar
They were 235s that TEA ported to 245s...
Awesome numbers Jeff. Glad it's finally running felt good going for a drive in that beast. I can't wait for the track outings and you getting booted immediately lol
Old 08-06-2014, 07:16 PM
CUR4VNM's Avatar
So they started out life as a 235 head and sent them in for the exhaust port work to get done someone dropped the ball which in this case may have helped out just a bit, but they made them 245's with the port work as well.
Old 08-06-2014, 07:18 PM
CUR4VNM's Avatar
It's a beast
Lol my street tires are a Hoosier drag radial
Old 08-06-2014, 07:21 PM
CUR4VNM's Avatar
Lol I know right Sucks I need a roll bar just to go on motor
Old 08-06-2014, 07:25 PM
JDMC5's Avatar
Nasty, gonna be fun with the 6 speed lol
Old 08-07-2014, 07:39 AM
ctd
ctd's Avatar
Ahhhhh, how do they hook gear 1 & 2?
Old 08-08-2014, 07:45 AM
CUR4VNM's Avatar
I haven't got to take the car out very much yet and its mostly been freeway. So I took it out last night and did some slower rolls like 30-40 in 2nd and they do their best trying to grab traction considering no burnout, full tire pressure and having to feather the gas lmao
I need to get a roll bar and take her to the track when the weather gets nicer out. See how they really work.
Old 08-10-2014, 09:59 AM
LS1 Tech Administrator
Patrick G's Avatar
Congrats Jeff. Glad to hear you're running so strong. Your combo is an animal for sure.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 08-10-2014, 02:27 PM
Goosecaddy05's Avatar
isnt the minimum recommended bore to run on the 235s a 4.125? i guess they still work with a smaller one?
Old 08-10-2014, 06:15 PM
Super Hulk Smash
JakeFusion's Avatar
235 can be used on a 4" bore... 245s can be used on 4.03" I believe but work well on the 4.07" LS3 bore...
Old 08-11-2014, 06:39 AM
Trick Flow® GenX® 235 Cylinder Heads for GM LSX - TFS-3061T003-C03
TFS-3061T003-C03
Large Image
OverviewApplicationSuggested PartsWarrantyShow All
Product Line: Trick Flow® GenX® 235 Cylinder Heads for GM LSX
Part Type: Cylinder Heads
Cylinder Head Style: Assembled
CNC-Machined Ports: Yes
Port Finish Type: CNC Competition Ported
Emissions Status: Non-emissions
Intake Port Volume: 235cc
Combustion Chamber Volume: 70cc CNC-profiled
Minimum Bore Diameter: 4.125 in. <<<<<<<<<<<What does that mean?
Material: A356-T61 aluminum
Combustion Chamber Shape: Heart
Intake Valve Angle: 13.5 degree
Intake Port Location: Stock
Intake Port Shape: Cathedral
Intake Port Dimensions: 3.250 in. x 1.070 in.
Intake Valve Diameter: 2.080 in.
Intake Valve Seat: Ductile iron interlock
Exhaust Valve Angle: 13.5 degree
Exhaust Port Volume: 80cc
Exhaust Port Location: Stock
Exhaust Port Shape: Oval
Exhaust Port Dimensions: 1.460 in. x 1.670 in.
Exhaust Valve Diameter: 1.600 in.
Exhaust Valve Seat: Ductile iron interlock
Valve Guide Material: Bronze alloy
Valve Seals: Viton® fluoroelastomer canister
Valve Seat Angles: 45 degree x multi-angle
Valve Spring Pocket Diameter: 1.480 in.
Valve Spring I.D. Locators: 1.300 in.
Valve Spring Retainers: Titanium
Valve Stem Locks: 7 degree
Valve Springs Included: Yes
Valve Springs: 1.300 in. o.d. dual spring
Valve Spring Seat Load: 150 lbs. @ 1.800 in. installed height
Valve Spring Open Load: 438 lbs. @ 1.200 in. open
Valve Spring Rate: 448 lbs. per inch rate
Valve Spring Maximum Valve Lift: .600 in.
Valve Cover Style: Center bolt
Spark Plug Style: Angle
Accessory Bolt Holes Drilled/Tapped: Yes
O-Ring Grooves: No
Heat Crossovers: No
Steam Holes: No
Quantity: Sold individually.
Cylinder Head, GenX® 235, Competition Ported, Assembled, 70cc CNC Chambers, Ti Retainers, 6-Bolt, GM LSX, Each
Quick Reply: LS3 416 Pat G TEA TFS
