How much will I gain with results
But regardless like I said before, the car was tuned before. So if we fixed this rich condition, and in effect the car picked up power, how would that not be because of the benefit of new exhaust? Where else would it have got this new power from?
Here's more links. Sanderson Headers. Headers By Ed.
Basically, if it is a MAF tune and all he changed was the exhaust, the MAF will not need adjusted again in the tune. In MAF mode, if there is less air moving through the engine it'll fuel less. It only cares about MAP and IAT to target AFR's. It doesn't look at RPMs. So it doesn't know that the engine is moving less air because it doesn't know it's RPMs.
In SD mode it doesn't know actual air intake and it uses the MAP, RPM, and IAT to calibrate the fueling.
The benefit of the new exhaust is less back pressure. It's pumping losses have been reduced, therefore the engine is more efficient at making power per drop of fuel (BSFC). So it doesn't NEED to flow more air because it has less resistance through the exhaust primaries.
So it lost exhaust scavenging, but gained efficiency, ending at the same power (maybe even a couple horsepower more). In the end, on this build, it was worth it IMO. He lost little low end torque, gained efficiency, and lost no high end power. But, it'll only gain exhaust gas velocities from here with future mods. So it'll show it's worth in the future with larger power gains than the 1-3/4" headers would've put out; especially since it only cost dyno time.
Uhhh, incorrect. Under WOT it is in open loop relying on a power enrichment and using the VE table to calculate incoming air. No MAF, No stock o2 sensors, straight up PE and VE.
What ever is in the stoich setting of the tune will get divided by the PE multiplier.
When PE multiplier is set to 1.148 it will shoot for 12.8afr assuming stoich is set to 14.7
14.7 / 1.148 = 12.8
VE is then adjusted to correct the actual airflow the motor is seeing through the MAP and RPM range.
I do agree that getting AFR in line could increase the power seen.
14.7 / 1.148 = 12.8
Plus the car sounds much better from the old exhaust setup. I am going back to the dyno in a few weeks with the 150 shot and purchased HP tuners and a wide band so we will see exactly what leaning her out does
14.7 / 1.148 = 12.8
However since he is SD then then pe is referenced with ve. The PE doesnt care which table is being used its just an equation for proper fueling.
I agree though that without correcting afr the results are not valid
We will know for sure in a couple weeks though and what it does with a 150 shot to boot. Wonder why any of our experieced sponsors havent never join the conversation.
I have experienced twice the power loss from going to bigger primary. Last time was when i changed stock manifolds to 1 7/8 in a stock LS1. I can feel the loss of torq but its not dynoed.
First time was when i did trackracing pretty seriously few years a go and did alot developemet to that race engine. I notice that in a 1800cc engine 2mm primary diameter grow i lost 10hp/10Nm. Length was all the same. At the dyno it went rich and it never came up when we corrected it, so i changed back to smaller primary. The bigger isnt always better. My LS1 street car what i have now, i really respect power under curve, so in a street use i think 1 3/4 is a best average shoot for every small cubic LS street engine.
