Ls1 h/c dyno number?
Old Jun 25, 2015 | 08:31 PM
Ws6-Matt's Avatar
Default Ls1 h/c dyno number?
I've been building a head & cam 98 ws6 and I'm looking for someone who has a similar build to see roughly what it will put down on a dyno and more importantly the 1/4 mile
Patriot performance stage two ls6
heads 64cc. 2.02" intake /1.57" exhaust
Comp custom cam 231/238 .617lift on a 113lsa
Ls6 intake (i might still buy a fast 92/92)
42lb injectors
17/8" longtubes
Ory pipe
Gmmg cat back
8.8" rear with 3.23
Build 4l60e
PTC conveter custom 3600
125hp wet shot
Also have 2000 harness and ecm for tuning reasons if that matters
Thanks in advance!
Old Jun 26, 2015 | 05:45 AM
HCI2000SS's Avatar
Depending on the dyno maybe 520-560 on the nitrous I'm guessing
Old Jun 26, 2015 | 07:17 AM
ragtopz28's Avatar
~535rwhp and 10.9 - 11.0*
*DA and weight will play a big factor on ET
Old Jun 26, 2015 | 12:32 PM
TXZ28LS1's Avatar
42lb injectors
17/8" longtubes
Ory pipe
Gmmg cat back
8.8" rear with 3.23
Build 4l60e
125hp wet shot
Thanks in advance!
I got a very close setup..
Livernois Motorsports stage 3 LS6 (as is)
TSP 233/239 112
TSP 1 7/8
3"Duals dumped/1 chamber flowmaster
36 lb injectors
3.23 gears
Circle D5c 4000 stall
ASP pulley
Dynoed 409rwhp/35X tq.. thats in 109 degree temp.. not sure what it would be on a cooler weather..
Hope it helps..
Old Jun 28, 2015 | 03:02 PM
7GRANDGERNADE's Avatar
TSP 233/239 112
TSP 1 7/8
36 lb injectors
3.23 gears
ASP pulley
Hope it helps..
What does your car run?
Old Jun 28, 2015 | 03:33 PM
MikeWS6's Avatar
prob 405/370 on motor
530/560 on spray
Old Jun 28, 2015 | 03:36 PM
Ws6-Matt's Avatar
Default Wow
I was really hoping for closer to 440
Do patriot ls6 heads just suck that much?
Old Jun 28, 2015 | 03:51 PM
HCI2000SS's Avatar
You really shouldn't be so concerned about dyno numbers
Old Jun 28, 2015 | 04:05 PM
ragtopz28's Avatar
This ^^ and stalled auto's can be a heartbreaker.
Old Jun 28, 2015 | 05:17 PM
MikeWS6's Avatar
Yes...
