Dyno #'s seem low on 99 SS
Old Sep 29, 2015 | 08:55 PM
bobby5's Avatar
Default Dyno #'s seem low on 99 SS
i bought a used low mile 99 hoss and was digging through all the paper work and found the dyno results. Its got MTI stage 2 ls1 heads, MTI R1 cam, FLP longtubes with no cats, magnaflow exhaust, underdrive pulley, lid, 90mm throttle body, fast 90mm intake, moser 12 bolt and alot of suspension parts. It only dynoed 384 hp to the rearwheels. That seems low to me. what do you guys think. what kind of 1/4 ets are people running with around 380 hp. six speed?
Old Sep 29, 2015 | 09:26 PM
Redbull87's Avatar
That 12 bolt is probably not helping dyno numbers..but I wouldnt be made with those numbers.Im willing to bet at the track the car will perform like a 420whp car should.Dont focus on what a sheet of paper says,go lay down some times and then see if things add up.If the car runs well and you bang a good number at the strip then who cares about the dyno results.
Old Sep 30, 2015 | 05:13 AM
MonmouthCtyLS7's Avatar
That's extremely low for a 6spd. Maybe it was a mustang dyno.
Old Sep 30, 2015 | 07:49 AM
HCI2000SS's Avatar
See what it traps at the track. If that's low as well then something is going on for sure
Old Oct 17, 2015 | 12:50 AM
bobby5's Avatar
I finally took it to the track and it trapped 117 mph . My 60 ft. Was 1.9 and I couldn't run better than a 12.5 . How good do you think it could run if I hooked better? What estimate horsepower does it have with the trap speed?
Old Oct 17, 2015 | 07:21 AM
HCI2000SS's Avatar
If this a full weight car (rims and all) You are making over 400 rwhp with a 117 mph trap imo
Old Oct 17, 2015 | 08:26 AM
bobby5's Avatar
Yeah its 100% full weight. I didn't know if it was capableof 11's?
Old Oct 17, 2015 | 08:34 AM
HCI2000SS's Avatar
With a set of dr's and a good 60ft a high 11 should be very doable
Old Oct 17, 2015 | 09:49 AM
Darth_V8r's Avatar
Moderator
117 is 420-430 at the wheels full weight. Earlier poster called 420 and was apparently dead on
Old Oct 19, 2015 | 09:27 PM
Powers00SS's Avatar
Perhaps if it doesn't have stock gears is why it is dynoing lower? I was looking into rear gears recently and they say if you go with a higher gear (numerically) you will actually dyno lower than with a lower gear.
Old Oct 19, 2015 | 10:46 PM
RevGTO's Avatar
Pontiacerator
Good discussion but it belongs here ...
Old Oct 20, 2015 | 10:21 AM
Marc 85Z28's Avatar
You didn't mention your transmission, but judging by the horrible 60' and ET you probably have a manual. 117mph and 384rwhp and through a manual indicates it may only have a cam and bolt-ons. How do you know the heads are ported?
Old Oct 20, 2015 | 02:36 PM
bobby5's Avatar
I have all the receipts for the heads and cam. There mti ls1 stage 2 heads.
Old Oct 21, 2015 | 04:32 PM
rpturbo's Avatar
Can you see a stamp on the heads? They should have some identification on them, otherwise, maybe they were pulled? The 117 is not a bad #, however, it is basically the same as my buddys Tick cammed , lid, exhaust and geared 01 SS 6spd.
Old Oct 25, 2015 | 10:59 AM
SoonerBrad88's Avatar
I made 444 to the wheels through a 6 speed and S60 rear and trapped 119 so you're in the ball park of 420whp. My 60' was terrible and I was on a 17" Nitto
Old Oct 25, 2015 | 06:37 PM
floman's Avatar
If I'm not mistaken, this must be the really clean 99 HOSS that "KatechJason" sold here recently. I was talking to him about the car and he was thinking that those dyno #s were possibly from earlier in the cars history possibly before the ported heads were added. He was also not sure what gears were installed in the 12 bolt rear. I do agree that it should be closer to the 420 rwhp #.
At any rate, the 117 mph trap speed is good for some easy mid 11 sec ET's. Congrats on the purchase of the car, that is a very nice ride and I am sure with some practice on the launching you should be able to improve on the ETs tremendously. You will have to launch pretty aggressively to get the full potential out of the car, but at least you already have the 12 bolt rear that will handle the drag strip launches way better than the factory 10 bolt. Good luck with that awesome car!
Old Oct 27, 2015 | 08:42 PM
RealQuick's Avatar
Fyi, I went to 2 different dyno jets (I got lower than expected numbers with the first dyno) and the 2nd dyno showed a 25rwhp increase. Dyno could just be low. Btw, I went 114.5mph consistently with a 368rwhp LT1 camaro with a 10 bolt, so I suspect 410-420rwhp is probably accurate.
Old Oct 27, 2015 | 09:50 PM
dkota1968's Avatar
I made 365hp on a mustang dyno on the cammed 346 and went 113.6 on 2.2 60ft. Go to another dyno if you really want to know, usually about 60 bucks. Plus you can check the tune. I've learned chasing numbers on a street car can get old, go out and enjoy it!
Old Nov 5, 2015 | 09:38 PM
99yellowz28's Avatar
I have a 99 with a m6 like you listed and mine only has a ls6 intake and tsp torquer v3 cam and it made 381whp last week on a mustang dyno
Old Nov 10, 2015 | 03:12 PM
30th t/a's Avatar
My WS6 with 416rwhp, full weight, full street, 17s all around did 12.1@117 in the summer and 11.9@120 in cool weather. 6 speed, 4:10s, stock rear. 1.78 60'.
