2002 trans am LQ9 370 nitrous cam
Alittle about the car, 2002 trans am,
New Thompson Motorsports LQ9 370 forged piston 2cc relief, steel top ring gapped at .025, H beam rods ARP 2000 rod bolts, PRC stage 2.5 5.3 heads 58cc, Quench .035-.037, ARP head studs, Cometic head gasket .045 thick, bore size 4.060, Fast 92/92 with a 92 nitrous plate, 85mm Maf, 1 3/4 headers, nitrous spec cam 236/250 115+4 .625/625 lift, Static compression 11.6 dynamic 10.11, Dynamics dyno, Shortuning James Short done a great job, as always.
Car made 395hp NA/ 553 on a 200 shot
Did you ever get yours to the track HCI2000SS?
Never made it to the track yet with the new tune and Fast intake, or the with the nitrous either, but I need to
Update : got to the track, weather has been horrible we had to break between sprinkles , the test results got me thinking bout my cam decision , may change it out to a NA cam, here it is
Just for comparison I will list my old set up car weighs 3890 with me in it
Old setup 346 ls1, prc stage 2.5 5.3 heads, ls6 intake, 239/242 111, na 114 mph @ 12.1, 200 shot 134mph @10.5
New 370 lq9 , prc stage 2.5 5.3 heads, fast 92/92, 236/250 114,
Na 117 mph @ 11.8, 200 shot 134.5 mph@ 10.47
It was painful to post the results, I now know why so many post never put in there track results , hopefully this will help others, that may be building something similar , forsake of argument this cam is designed for nitrous above a 200 shot , I will keep posting results as I go up in shot size, alway a work in progress
do not be upset !!!!
just ask brian tooley and he will guide you through.
quick note : your headers is not nitrous friendly and i believe it is holding your engine back
good luck
good luck
