WCCH Stg3 l92 headed 408ci what will it make!?
Engines almost finished just waiting to get the intake and heads back from machine shop!
Engine:
- 408ci 12.5:1
- Callies compstar rods/Crank
- Wiesco +5cc pistons tool steel pins
- WCCH Stg3 l92 heads PAC1208X Springs
- Smallwood Racing Development HR nitrous cam 259/279 .652/.632 114+4
- Morel lifters 5315
- 3/8 pushrods
- 1.7 ratio t&d shaft mounts
- Edelbrock Super Victor 4500 flange done by Fast Forward race engines
- Accufab 4500 TB
- 78lb dietsch werks injectors
- 1 7/8 inch primary 3" collector
- Magnafuel 750
- Nitrous outlet stinger plate with progressive
Trans:
-Built 4L80E Full Manual with Trans brake
-PTC 4500 nitrous converter
-PST Driveshaft
Rear:
-8.6" 10 bolt 4.11 Eaton (weak link)
Calvert Caltracs and there 9 way adjustables
This is going in a 2004 RCSB Silverado
Engine:
- 408ci 12.5:1
- 3/8 pushrods
- Accufab 4500 TB
- Magnafuel 750
Trans:
-PST Driveshaft
Rear:
That's a pretty serious build, .650 lift is kind of high with stock rockers.
I think I've seen threads on here where Brian said .620 is the most they recommend with stock, I'd bet the cam lobes probably have to be considered also.
When I talked with Martin about it and he specd the cam it was specd to run the stock rocker however we did not talk about spring pressures I think I may order the 1207x springs and then get a better rocker down the road after I recouped some money
Location: Coast of San Mateo County Between Pacifica & HMB
I was told by CHE .630" lift, ~ 420 lbs open pressure (without increasing the bolt
size on the rocker) and moderately aggressive lobe profiles (CAMMOTION) was
The envelope edge they were comfortable with. Really Challenging to get a good
Wipe pattern even @ .630" lift with the stock rocker.
Good Luck
Good Luck
Good Luck
Good Luck
The 1207x's are 436lb so I will be triple checking. If the patterns not good I'll have a set of ls3 rockers for sale, anyone have thoughts on these
http://www.briantooleyracing.com/685...ers-sk701.html
I've read some guys claimed premature wear with higher lifts & stock rockers.
