H/C Dyno sheet Thoughts?
I see you went with the fast TB & have a idle issue. A lot of people do. I made this thread after finding myself.https://ls1tech.com/forums/generatio...ast-92-tb.html
Works well and cheap, it will capture around .25 quarts every 300-400 miles.
Thanks for the link.
At this time, It would be ok to experiment with different exhaust system options, and put remaining effort into the transmission and drivetrain. If you are still looking for more power, besides adjusting the exhaust system (I would not modify the intake side much, I would not upgrade the throttle body, feel free to ask why) the best option is nitrous, a progressive system (don't be cheap with nitrous) perhaps for its stealthy character gentle stepping up in power (more control, earlier nitrous action) will help the power feel more natural. Skip the nickle and dime options (dont try to get 5hp from this, 8hp from that).
Another option I recommend is reducing vehicle weight and rotating mass. Buy a light set of wheels, driveshaft, rotors, take anything out of the vehicle you do not need.
I've started a 454 lsx build over the last two months that will be going in one of many cars around the farm just haven't decided which yet.
It should be a fun yet non economical build that will maintain street manners.
I'm shooting in the dark and going to say the TA with the Fast 92 combo should easily push it to 460/425. Which is plenty for a Nice day DD IMHO.
Keep in mind now that the Fast 92 combo is on it, the question will be what came first? Chicken or the egg?
These two modifications will be the last two performance modifications on the engine, or yet power modifications.
The dyno was booked through May 31st so it will be a couple months before and hard data can be presented.
Keep in mind though same tuner/same dyno. So this will be real world expectations and gains/losses.
Thanks for the positive reinforcements guys.
Engines receive some benefit from a proper length/size exhaust, so don't expect the full open setting to give best performance if the engine isn't literally using every square inch and still needs more to breath. It might give a best/better peak number but what you lose under the curve could leave you worse off.
From past Z06 ls6 tinkering with collector designs, the kooks performed better than others and hence my decision for using them in this build.
Keep in mind the Trans Am current primary's are 1.750", not 1.875" like most preach on. This thing was built as a lowend torque machine and that persuaded me to stay with the 1.750"
My red Z06 felt quite sluggish with the 1.875" and mild 243's, as well as the Dart 205's on the same car.
The lowend on this TA is crazy, but that has more to do with the compression ratio provided by the TFS 58cc chamber vs 64cc 243's.
We will play with the cutout, and see what power is really gained.
The biggest wow factor hands down has been the 92mm intake. I drove the car today and without even touching the tune running 12.2-11.9 afr @ WOT, it just feels so much smoother while pulling so much harder. it really seems like the bucking around 1100 rpm has diminished? Maybe its imagination?
TR is very quick 19% TPS, and the tires break loose 1 and 2. It will be interesting to see the final tally.
Bill I own many many cars it's a real number. It runs very well and met my expectations.
I can't express how well the combination works. TFS cathedral port heads make BIG power at the track or on the street. The venue is up to the man paying the piper.
Great job brob!
Ported 243s are great heads but I would still expect them to be outperformed by a set of CNC Trick Flow aftermarket castings.
So I really just don't see a reason to be skeptical of 440rwhp which seems fairly modest for the combo. Now that he has a Fast intake and a cutout I wouldn't be shocked to see 460+ out of it.
Seen the G5X2 cam in a buddy's car put down 420 to the tires on
(+-) 1.5% on two separate dynojets in the area.
This was a stock untouched 241 head car with the only other modifications being Kooks 1.875 headers. So in my book it was a true cam only.
Car ran 7.80's@93 hope this helps Bill.
For the gains it wasn't worth it in my eyes. I'm after a nice driving combination with good manners, and was not trying to impress myself with dyno numbers.
If you read my statement above about how my drivability improved that should be enough for you to pull the trigger on the 92 and not worry about having to space this or change that.
Honestly it took 45 minutes start to finish. For the cost difference it may seem like the 102 is a bit cheaper. When in all honesty time is money.
