H/C Dyno sheet Thoughts?
Stock untouched LS6 Intake and TB
42lb Injectors
1 3/4 Kooks with custom 3" FM Merge Y through stock catback
TFS CNC 205's out of the box 11.5:1
BTR Stage 3 NA
What's next? Thoughts?
AFR @ WOT 12.4
SAE Smoothing at 5
Last edited by brobinson216; Feb 7, 2016 at 02:05 PM. Reason: Added a bunch of junk
I was thinking a set of 4.30's and call it done. Will this setup benifit that much going to a Fast?
The first thing I would do is get that stock catback off. You may like the sound/tone & sleeperness of stock tips though. I believe a fast will help power, across the board, no matter. The easier choice being the 92 as you can use the stock fuel rail & don't have to grind. The 102 will help more, with power, but needs aftermarket fuel rails & it may contact the top of the water pump/grinding.
Seems you're making good power as is.
I agree the 4.10 will most likely fit the bill. Appreciate the insight!
To be honest I built this motor trying to prove what I already knew. The gains with the smaller runner heads vs. > 210 runner heads would be on par being a 346 ci. I found that out in 2005 with one of my z06's and a set of Dart 205's. Yielding max HP was not in the original scope simply put it's a fun streetcar. Now it's time to see what it really has in it.
I will order a fast 92 combo and see what that does for it.
Holy **** that woke this car up. The throttle response is so much crisper and responsive. To those who have the H/C and considering the Fast, make the move now as you will not be disappointed.
Install went smooth, now its time to get some data logs and make some adjustment.
The TPS is sticking around .04% at idle, so that's the primary area of concern right now.
It will be May 31st before it can go back to the dyno. Maybe I'm in the wrong buisness?
20-25+ RWHP and just as importantly 15-20+ lb ft through pretty
Much their whole curve 2500-5500,6500 RPM not to mention
MUCH crisper throttle response on the table with LS6 intake & TB
compared to a well ported FAST 92 & 90/92 TB let alone the
FAST 102! or 383" LOL
Good Job!
Enjoy!
Good Job!
Enjoy!
11.5 comp and the right head combination for the CI used. This dyno is far from generous. It was well thought out, not my first rodeo.
I see you went with the fast TB & have a idle issue. A lot of people do. I made this thread after finding myself.https://ls1tech.com/forums/generatio...ast-92-tb.html
