383 Stroker, heads, cam results seem odd
This is the first time it has been dynoed and i plan on bringing my car somewhere else to get a second opinion but these results seem very odd for the amount of work i put in the car.
I am running:
-ls6 intake
-dart pro 225 heads
-eagle 383 stroker kit
-tsp xpipe dumped at the axle
-cam motion 230/234 custom cam
-373 gears
-built 4l60e tranny
Just curious what you guys think.
It is a mustang dyno but i don't think they are THAT far off.
I have been told that i may have measured the push rods incorrectly, but i am pretty sure i was accurate. One other thing i heard is the trans pressure may be too high...(do not know much about transmissions, i leave that to the pros lol)
I uploaded the graph. If you can not read the numbers they are:
MIN: Torque: 119 Power: 73 at 3376 rpm
Max: Torque: 352 Power: 357 at 6199 rpm
Avg: Torque: 326 Power: 342 at 5527 rpm
I am running:
-ls6 intake
-dart pro 225 heads
-373 gears
-built 4l60e tranny
What about the max numbers? They seem VERY low to me. I have seen cam only cars run better numbers than that, maybe not very good graphs, but definitely better numbers.
All the cylinders are running fine. I am running a 3800 stall. Can't remember what brand/model it is off the top of my head for sure. I wanna say TCI though.
Moderator
If you're still reading low on the next dyno, try pulling plug wires one at a time and see which one (or more) doesn't make a difference.
He oddly seemed happy with the results; real nice guy, just couldn't get anywhere arguing with him because he thought everything looked good.
It'll be a few weeks before I can get it to a dyno again.
I'm sure if one of the cylinders wasn't working properly, he would have told me when he tuned it.... It drives fine though
I am aware of that. But I've seen cam only cars put down more than this. This is showing pretty damn close to stock numbers and it's stroked with heads.
just a guess but with that combo on a dynojet with a locked vert i would think 430-450 rwhp.so if your vert isn't locked and on a md those numbers seem close. as already suggested,hit the track and see what kind of times it runs. should be mid 11x in the 1/4,mid 90's in the 1/8th just guessing.
