07' CTS-V N/A 570/520rw
It was 94* in the dyno room and it was raining around my area this morning so not the best day to dyno. I am attaching a screen shot of the pull. As you can see, I am out of air and MAF at 5,600 rpm. Coolant temp was 195* and tire pressure was at 35psi. Car was strapped down hard since it spun the first pull. I was battling a rich condition that I couldn't get rid of from 4-5,600 that cost me about 10rwtq. I was also having to use the PE table for fuel after 5,700. yes, the VVE table has been tuned. I think the combo as it sits on a good day would go 580/535rw. With some mods I have in plan for who ever buys it, probably close to 600rw. I just re did the entire top end last weekend and changed all the fluids from front to back with RP.
Mods:
Mods: 15,000 miles on motor and mods:
BER LS3 based 427 K1 and Wiseco 12.0 SCR 8.7 DCR (a little lower after re-porting)
BER PORTED 243's with SS 2.04" valves. 340+cfm at .600"
Cometic .040"
BTR springs with Ti retainers
Comp trunions
7.35 Comp PR's
BER ported FAST 102 intake
BER ported 90mm TB
BER custom cam 243/251 .624/.624 113+4
52lb FIC injectors
BER custom 4" CAI with LS7 MAF card
BER custom PCV system with catch can and check ball valve cover breather
MSD wires NGK TR6 plugs
OBX headers with cat's (no interference issues)
BER custom Dual 3" with X and dual electronic cut out's, stock mufflers
Power Bond U/D pulley
160* T-stat
CS motor, trans, diff mounts
LS7 Clutch and slave
Wilwood Master
Pissnuoff shifter with ALL the trans mods
VoodooChicken drive shaft
BER custom WB02 street tune Get's 16.5 mpg average and 24 mpg on the highway. It is my daily driver.
I have 275's on the rear
Is this on 93 octane to support the 12:1 compression? Great fuel economy too for a decent sized cam!
What kind of dyno was it?
I run 93 octane. I had to rework the valves, seats and combustion chambers and didn't have a chance to mill them so I didn't bother cc'ing them. I know the compression is down a little since it took two more degrees of timing than it did before with no hint of detonation.
It pained me to use this cam since it is pretty mild for this combo. Drives like a dream though and gets good gas mileage. I really wanted to go with my money maker cam. I could have at least tightened up the lobe sep a degree on this on. The exhaust gained 30cfm also on the re-port so some more intake duration is needed now. The new numbers probably need a cam with only about a 4-6* split.
It's good to see cathedral heads holding their own and making power like that, especially 243 castings.
I think in this combo it could be the headers or cats that are not scavenging as well as they could be so it responded well. Plus when you add an actual header to the exhaust on the flow bench the real story gets told. I will tell you that high lift flow doesn't help much at all. It is all bout the .300-.500 lift range. The flow characteristics are no where near what a straight pipe does. Most of the flow gains with the new port job are in the .500-.700 lift range. I did make same good gains down low as well sonce I ported these heads 2 years ago and have learned alot since then. It is all about seat and chamber at the lower lifts.
