618 RWHP LS7 Dyno testing Sat.
BEI 438ci LS7 Wet Sump
4.125 Bore 4.100 stroke
Sleeved L33 block
13.7:1 compression
Ported BEI LS7 heads
Ported BEI MSD intake
BEI Custom cam with only 12* overlap-mild driver cruises great at 1600rpm in 6th. I routinely shift every gear at 2k rpm for normal driving.
Bushed rocker trunion upgrade
3/8 pushrods
BEI dual springs with ti retainers
Delwest TI intake valves and hollow steam exhaust.
2" Kooks and Kooks 3" x-pipe
Kooks 3" axle back
E85 or walk home.
Going from the stock Ti exhaust with bypass mod to the Kooks 3" axle back netted 0 hp. Which I had suspensions that it would be a net zero gain. More surprisingly though it is much quieter the Ti exhaust. BTW I have a modded Ti exhaust for sale haha.
The Haltech CAI picked up 10hp over the C5 style Airraid intake.
Sleeved L33 block
13.7:1 compression
3/8 pushrods
Kooks 3" axle back
E85 or walk home.
EDIT:
I was thinkin' even smaller.....like closer to the first sized cam that Jake guessed at.....
KW
