LS2 GTO A4 with 218/224 cam
Thought I would share the results of my woman's daily driver. Its a 2006 LS2 GTO with the 4L65e, about 100k miles and a few mods. Here is what she has:
- BTR Stage 3 Truck cam - 218/224 113LSA
- Stock GM Blue springs
- CSP ported LS2 Intake mani and TB
- VR intake
- Kooks 1 3/4" L/T into catted X and full 3"
- UDP
- FTI 3200 Stall
- 243 Heads milled .030 and a good VJ
- Tuned by yours truly
The best it has run so far is 11.91 @ 113+ before we put it on the dyno. On the dyno it picked up roughly 25rwhp by leaning it from 12.3 AFR to 12.8-13.0 AFR. It should pick up a little at the track on the next outing. Race weight with no driver is 3580lbs, so its a full weight GTO.
- VR intake
- UDP
- FTI 3200 Stall
I could barely muster that kind of power with an HCI M6 GTO so you sure got some skill tuning there...
It had a 1/4 tank gas and drag pack on it. The same way I race it at the track. It still even has the tow hitch brace and cats on the car. It's a certified scale.
Before the VR intake it had a crappy K&N, made 418 on another dyno. After the VR install the WOT AFR was about 7% lean. The intake definitely helped out.
- VR intake
- UDP
- FTI 3200 Stall
- VR intake
- UDP
- FTI 3200 Stall
I was surprised as well it picked up that much. If it doesn't rain tomorrow we will go to Darlington and see what she does.
I use a cheapo LC2 Innovate WB.
The cam is straight from BTR, comp cam lobes.
ok those wbs can be pretty far off. I bet you were richer than 12.3 which is why you gained that much. My old dynojet wideband used to be off by about .5 rich which is why I invested in a ballenger 500.
I have an AFR500 as well but never really noticed a large difference between the two. It did 430 and 431 back to back so if it picks up .1 to .2 at the track then the gain is verified.
Gains at the track is all I really care about honestly.
Will do. It will be a couple months, I have to rebuild the trans in my truck first.
Forgot to add, torque was 403 @ the tire. I'm not sure why he only sent the HP graph to me
Sounds good. Just lemme know, I may have something by then but hit me up anyway.
Question. With 430rwhp shouldn't it be trapping a bit higher than that? I'd say at least 117-118? I'm wondering why I see so many gtos putting down good hp and tq numbers but running slower times than they should be at that power level (no offense meant).
No offense taken at all. Pray, long standing member here, asked the same thing after the 431rwhp dyno pull. He has been helping me with some upcoming mods and was there at the dyno and at the track when the car ran the 11.9 ET. The tune I ran the 11.9 at the track was only 403rwhp on the first dyno pul. So that may be a bit why the mph seems low. If the car runs 115ish mph with the 431rwhp tune I would think that is a good gain. Like I said hopefully it doesn't rain tomorrow and Darlington is open. I will update if we make some passes.
So I had a third gen camaro a few years back, it made 407rwhp and it weighed 3550 with me in it. It trapped 120-122 and ran 11.50's on nt555r drag radials. I can't help but wonder tho, say yours weighs a couple hundred lbs more with driver, making more power than mine did, it should be around 118mph trap speed one would think? And again, no smartassness meant at all. I just got an 04 gto and I'm trying to map out my modding plans. I may skip the cam and heads and concentrate on getting the car and drivetrain setup and efficient first then put a bigger motor in it. I hate to go waste money on heads, cam, intake etc if my goal won't be met (120mph trap speed daily driver like my third gen camaro) or even close to it with this motor. What's your thoughts? I'm at an even bigger disadvantage than you are with me having a 5.7
True but on my old car I had a 2600-2800 vigilante convertor and I didn't see much (if any) difference locking the convertor in the 1/4. I went through great pains trying to tune it with locking up but it just seemed to slow it down (lack of power?) I have a yank truck thruster (I got it in a trade deal) 3000 I was going to put in the car but I'm considering selling it and getting a car series yank convertor. I was going to build the trans as efficiently as possible while I have it out. I build my own transmissions (not saying I'm a pro but I try to pay attention to details) so decreasing drag in first and second gear is important to me, might be why the 3rd gen ran so well.
it has to be locked at the right rpm for it to work. It will bog the car down if locked too low. Essentially, it extends the gear another few hundred rpm so you sit in the peak power sweet spot longer. Its best of both worlds. Unlock to get the torque multiplication at lower rpm, then lock at highee to extend the gear and plant max power to the ground.
Ok that makes a little more sense but I must ask....
There are a lot of factors at play in every setup but in all honestly I have no more than 5-6 passes at the track on the GTO. I had lots in my old B4C LS2 Fbody, tons in my C6 LS3 Vette, but only a handful in the woman's car so far. I feel certain there is more MPH in the setup with adjusting shift points and tinkering with the lockup. The biggest problem is the huge drop on the 1-2 shift in the 4L60 during the run. Originally I believe the tune was shifting out of first around 6300ish RPMs and looking at the dyno sheet I will extend that first gear shift out to 6500-6600 and see if that helps. If there is time before the new setup to tweak these things and test them at the strip I most certainly will.
On that note, since I am rebuilding my 4L60e in the truck and its my first time doing a transmission I am open to any and all tips you may have! I have several books and a video but real world experience goes a long way. If you don't mind I will PM you for more details, thanks.
