Mamo 223 fast and cam results (c5z)
Just wanted to share my results with the 223 custom cam and ported fast 92. The car made 453/403. I took it to the track last night and my best time was a 12.2 with a terrible 60.
Moderator
Received 1,835 Likes
What RPM were you shifting at?
Moderator
Moderator
Moderator
Nice going and great having Mamo in your corner.
If one of your goals is et, I'd consider doing gears like 3.90s and practicing alot on the launch. Shoot for high 11's then mid 11's and lower. Your car is capable of 10's under the right conditions and some astute track preparation.
...just my 1/4 mile mentality coming out here.
I prefer Hoosiers drag radials for your car/setup if you had to go with a drag radial.
The best way to learn the launch in a c5Z is with a bias ply slick.
If you can get a 16" rim that's even better.
Either way I can guide you and safety first.
The clutch seems to be dragging,the car rolls a little while I try to put in gear and the shifter is super tight and hard to get into gear(mgw). I'm going to be changing it out for a monster twin disk. I had toyo r888 on it these runs on 18s. I just ordered mt et and am going down to 17s and skinnies in the front.
