New HCI bolt on 6.0 build
So i have a 235/240 cam, prc 227 heads, fast wilson ported 90mm intake and TB, slp lid, stock MAF, 60lb injectors, 6.0 iron block swap, 3600 stall, 3.73 gears and Pace setter LT hraders x pipe dumps. Will be dynoed and tuned on a Mustang Dyno. Any guesses?
430. Trying to help so don't take it wrong but choking down a 90mm TB/IM setup with a slp lid and stock 75mm MAF is never smart. Since you're getting tuned anyway I would suggest getting 98mm lid, 85mm MAF, and 4in silicone intake pipe beforehand.
Hard to say since dynos vary. I've even seen mustang dynos turn out higher numbers than dynojets. But coming from my LS1 to my LQ9 i did notice a small bump in torque down low. Regardless of the dyno number I say you have around a 450 hp setup there
