My 376" NA Solid Roller Build
Originally I got a great deal on a set of lightly used Wiseco 12:1 pistons designed for a stock rod/stroke. So I ended up buying a set of Scat rods with ARP 2000 bolts and a stock LSA crank. After tearing down a donor L92 block I had and taking it to my local machine shop (IDM Speed and Machine) it turns out the block was worn enough that a clean-up hone would put it to 0.008" PTW on those Wisecos. Sooo.... I ended up buying a set of 4.07" 12.2:1 Mahle's with Lunati rods from TSP. The final build on the engine is as follows:
2008 L92 Block 0.007" Over
12.2:1 Mahle Pistons
6.125" Lunati Rods w/ ARP2000 Bolts
LSA Crank
ARP Main Studs
Melling HV/HP Oil Pump
King Bearings with 0.0025" on the mains and rods
LOJ Private-Label CNC Ported 823 Cylinder Heads, Stock L92 Valves, Stock Guildes
PAC Dual Springs with Ti Retainers
ARP Head Bolts
Stock 0.051" Head Gaskets
LS3 Valley Tray
LOJ Spec LLSR Cam by Bob at Cam Motion
5/16" 0.120" Wall 8.100" Manley Rods
Jesel Roller Rockers
Morel Link-Bar Solid Lifters
LOJ Oil Pan
LOJ 1-7/8" to 3" long tubes by Kooks
Fast 102 w/ Mid-Length Runners, Fast 102 Throttle Body
LOJ Cold Air Intake
The trans is an ATI Competition TH400 w/ a Brake and a Reverse Manual Body
The converter is a 4500RPM Stall 9" unit from ATI
The car is on 26x11.5" Hoosier Slicks
3.69:1 Stock Rear Diff/Axles/Suspension/etc.
The whole idea was to build a motor that would RPM. This was for a couple reasons:
- I like high reving motors
- The car is still on stock rear suspension, and I plan on leaving it that way. This presents a problem because there are not many gear options for the 300ZX TT R230 differential. I'm already running out of revs at 128MPH and a 7000RPM limit. If I want to go quicker and faster, I can put a 27" tire on it, but that's not enough. The 27" tire combined with a 7500RPM limit and 15% converter slip will get me to 141MPH at the limiter in direct. More on that later...
So I assembled the motor on Friday, installed it on Saturday, Started it up on sunday, let it idle and rev for a bit, drained the oil and put in dominator 15W-50, and trailered it out to Gettysburg on Monday for Jeremy Formato to tune. The results were surprising to both of us...
That's 545WHP@7400RPM through a high stall, auto, and slicks.
545 WHP is 641 Crank at 15% Drivetrain Loss, 681 @ 20% and 727 @ 25%. Jeremy seemed to think this setup is likely in the 25% loss area.
Using a 1/4 Mile ET/MPH to HP calculator for the old setup, a 10.5@128 would be 545 crank horsepower, which is exactly what TSP said their cam setup would make, so I believe that calculator to be accurate.
If the new setup is making 641, the car would go 9.9@135
If the new setup is making 681, the car would go 9.7@138
If the new setup is making 727, the car would go 9.5@141
FWIW the car's race weight is 3282lbs. So by the above numbers, you can see why I would need the Rev's to keep the stock diff ratio and still not run out of gear.
Anyway, just thought I would share, can't wait to get to the track and actually see what the car does.
I am more in the fixed drivetrain results camp, I would estimate
Your crankshaft HP between 645-675, (100-120 HP drivetrain loss).
Who is LOJ, and are you able to share Head flow #s and Cam
Specs? The peak is similar to my 396", 7100-7300 RPM with a
FAST Mid Length Runner as well. Should really rip, in for track
Results.
I've got to dig up head flow numbers, but I'm happy to share the cam specs.
238/248 112+2 0.697/0.671
We run a hydraulic 239/251 on 110+2 in a SBE 10.4:1 LS3 and have gone 10.13@131 at 3200 pound race weight w/ a powerglide in a less aerodynamic wagon.
Also if your converter is slipping 15% at 7500 there's a problem. Slip should decrease with RPM and at 7500 should be no more than 8% and 6-7% should be achievable.
Cool car and congrats on the results!
Very nice motor. We continue to see these shorter length runners and LLSR combined with good heads really just getting it done. A very impressive motor that likely would have dyno'd 570 at the wheels through a T56
Agreed!
I'd love to extend the RPM more, but those truck intake valves have me worried a little bit. I'm going to get kicked out of the track no matter what I do, so we'll just play it by ear.
Work the eighth until you feel good, then do your hero run. if you're lucky, byt hte time you dialed int he eighth, they won't be watching you any more...
Beautiful car you have there. 9s will be easy.
Long time AMSOIL User/Dealer here , I am using
Dominator 10W-30 with 30 PSI+ @ Hot Idle & 73 PSI @
7600 RPM, with similar clearances. Curious as to
your oil temps and pressures, and decision on 15W-50?
I think your cam specs/size for your valve weight &
RPM is spot on FWIW.
Thanks!
