Expected power with an Lsa blower on a 5.3...
He has no need for -8 feed. 1000+rwhp on ethanol? Sure step it up. 600rwhp on gas? No need. Install a -6 return, post filter, regular. Your pump kit should have a sock/prefilter that comes with it. Shouldn't cost much more than $550 before injectors.
I don't buy generic lines and fittings filters/regulator and so on, That's the one thing I won't hesitate to buy quality parts. Seen a couple cars catch fire because of junk fittings or fittings that don't match the fuel line.
I went -8 because cost wise it only added less than $50 to the cost over going all -6. If you price it all out there is not much difference in the cost of fittings Most were less than a $1 more each and the fuel line is only $1.25 more per foot.
Current turbo cam in my car now: 219/223 .617"/.595" LSA114+3
Ls1 stage 2 Blower cam: 227/243 | .625"/.615" | LSA115+4
What do you guys think, would it be worth the 400 bucks while Im in there or should I stick with what I have? If I do decide to swap the cam, Im also thinking about going with the Texas speed bald eagle ls1 blower cam. That cam has a 227/234 duration @.050. They don't show any other specs on the cam.
This guy made 705 at the tire with that cam in an ls1 with a ctsv blower, prc lq9 heads, and I believe E85.---
Boost comes in early and is done before a turbo would so it will benefit from a cam designed for it.
I mean NA I'd be worried about reversion, but with a blower you shouldn't have any issues and you'll make more power with the bigger cam
So all in Im looking at about 1200.00 for the COMPLETE fuel system. Also this is going in a 3rd gen Camaro, not sure if I mentioned that..
I decided on a -6 feed using the factory 3/8 hardline and a -6 return with braided stainless hose. I didn't go larger because well.. I don't need it. The -6 will support up to 700 rwhp I believe, so Im leaving it alone. The line has already been replaced and and ends are currently fitted with -6 an hose fittings, so why not leave it?
Pump wise Im adding a second walbro 255 for a dual in tank setup. The second pump will come on via the hobbs switch. Both lines will come out of the tank and join a -6an y block to a single -6an hose. This hose will go to a -6an inline filter, and from there connect to the factory 3/8 line. The hardline ends in the bay where I have a braided line connecting to the rail. Basically Im going to connect the braided line to an aeromotive boost referenced regulator, which will then go to the factory return less zl1 rail. The return will exit the FPR and go back to the tank. The return will go through the top of the tank into a -6an bulkhead and 90 degree fitting.
I also have a vacuum block picked out for the hobbs switch and hoses going to the boost gauge and FPR. Im pretty sure I have every last fitting and hose accounted for, but I wouldn't be surprised if I need to order something else when install time comes. I even got a pressure gauge to screw into the fpr.
if you upgrade, go to his small valve 205cc or trickflow 205 cc heads meant for that smaller bore. Then cam it for that.
you have low 10 seconds hp if you can get it to hook and drive it like you stole it. Good job on this build
