Highest HP From 243 Heads?
Old Jun 15, 2019 | 02:01 PM
  #81
SoFla01SSLookinstok's Avatar
Originally Posted by bortous
Did you make extra power with the 2 inch headers?
My guess would not be more than 10rwhp. But I could be wrong. Would have been cool to do dyno before then right after install. Just couldn't do it. From the butt dyno the engine likes them & is more happy at 7k rpm. Although my exhaust is 3" x-pipe dumped. TSP true dual. So the 1 3/4 did ok. Putting that dumped exhaust on was 20hp/20tq.
Old Jun 15, 2019 | 02:25 PM
  #82
bortous's Avatar
When I dynoed mine, I saw the print out and it was within 1.5hp difference from the 1 3/4 to the 1 7/8.
Torque curve was the same.
Might work better with a bigger camshaft though with a bigger exhaust split.
Will see
Old Jun 15, 2019 | 02:37 PM
  #83
Will see
Interesting. So not much power gain. If you don't mind what were the dyno numbers?
Old Jun 15, 2019 | 02:39 PM
  #84
Will see
Slight gain. . I would have thought more difference in power between the header sizes
Old Jun 15, 2019 | 02:43 PM
  #85
bortous's Avatar
With the 1 3/4 headers I was at 503.5 rwhp
With the 1 7/8 headers I was at 505 rwhp
Pretty much nothing.
As I keep mentioning though, this might be because engine is not spinning high enough.
Going for a 12 degree overlap to a 24 degree might make a difference.
Old Jun 15, 2019 | 02:45 PM
  #86
bortous's Avatar
I thought so too.
If I was building another na engine up to 800hp I would stick with the 1 3/4 size.
I have a feeling the bigger header might be better over 6500rpm but I will never know.
Old Jun 15, 2019 | 02:53 PM
  #87
HioSSilver's Avatar
I had the se td x dumped. Was just way to loud for me. The se td x out the back is a nice system for the $.
Old Jun 15, 2019 | 02:54 PM
  #88
I thought so too.
Good point. That is likely where the larger tube size really shines.
But it's good to know there is little or no loss below 6500 with the larger header.
Old Jun 15, 2019 | 03:01 PM
  #89
It is pretty loud. What size pipes are on the se td's?
Edit. 3". Nice.
Old Jun 15, 2019 | 03:45 PM
  #90
HioSSilver's Avatar
Yea they're 3". Same system the bolt on ls6 made 451whp through. They're also easy to quiet down more if one wants to. Pop the tip off and you can shove a spiral in the muffler......takes like 5min if that once they're fitted.
Old Aug 2, 2019 | 10:20 AM
  #91
BADD SS's Avatar
I made 502 on my ls1 with 243’s on a mustang dyno, with a 9” and 29” slicks. I made 540 on the same setup but a 13.5:1 ls2, with the same 243’s. This was not a “happy dyno”. Trapped 132, and 137 mph respectively.
Old Aug 2, 2019 | 10:35 AM
  #92
Darth_V8r's Avatar
Moderator
What ET with that 137? That is badass on a ls2
Old Aug 2, 2019 | 10:54 AM
  #93
BADD SS's Avatar
10.41, with a 1.72 60’. I went through +- 15 clutches until I put in a soft lock style clutch. All the tracks that were close are closed now so I never got the chance to dial it in as a slipper. I had 60’d 1.42 on a monster stage 3, but that clutch would not work above 7500 rpm. (I shift at 8000-8100)
Old Aug 2, 2019 | 11:53 AM
  #94
Darth_V8r's Avatar
Moderator
I struggled to get 60ft down on mine. Ended up going to bias ply. Then if the tire spins it does not just give up like radials. QTP was big over ET streets.
Any other build details you would like to share? Or maybe a build thread? Most of the 500+ Ls1 sbe builds have AM heads. And most even with AM heads get stuck around 480.
Edit - not doubting. Just impressed.
Old Aug 2, 2019 | 12:29 PM
  #95
BADD SS's Avatar
I had had a bunch of threads back in the day, I really haven’t posted here in 5-6 years.
Its a kaltech h/c package. T4p 799’s, “with special sauce” as it was labeled. Cam was 25x/26x .680/.660 I believe. Ported supervic, Manton pushrods, 13:5-1 comp ls2, now it’s bumped to 14.2-1 ish. I built the suspension/rear end housing in my welding shop. I got tired of trying to get updated in the fastest six speed list so i gave up here, I don’t know if that ever did get updated. It’s like a ghost town here now!
Old Aug 2, 2019 | 12:38 PM
  #96
stilealive's Avatar
My 436ci stroker made 500 RWHP/503 RWTQ....back in 2000......also had a stock TB and LS6 intake. 11.3:1 cr. 4L60E. 1 7/8" LTs.
Old Aug 2, 2019 | 04:55 PM
  #97
DoggyB22's Avatar
Brought this thread back to life huh? Well back around when I made this thread I was wondering because based off my set up. My set up is a 346ci 90mm intake, 92mm TB, bigger size custom cam, ported/polished 243 heads, 9" rear end with 28" slicks through a m6. Did 456rwhp & 421 lbtq. But unfortunately during the dyno I was aware of a ticking noise going on that had started prior. I didn't wanna spray it to cause any more damage but soon after we took apart the engine & found out that my piston had gotten damaged & came in contact. So took apart the engine fully forged the bottom end & well see what I'm able to put down & take it to a track
Old Aug 10, 2019 | 10:43 PM
  #98
64post's Avatar
624hp on a dyno. NASCAR spec LS2 K&N pro series motor, 364 ci , Cnc ported Wegener Motorsports 243s with titanium valves, often spun to 8000-8200 in and out of turns. ( Carbureted)
Old Aug 11, 2019 | 10:58 AM
  #99
HioSSilver's Avatar
Hopefully the second cumming of muh ls6 be done soon.
Old Aug 14, 2019 | 07:17 PM
  #100
AINT SKEERED's Avatar
Interesting thread
