TSP Torquer V2, PRC 227, Fast 92 (Mustang Dyno)
Old 05-01-2018 | 07:22 AM
omaha stylee's Avatar
Default TSP Torquer V2, PRC 227, Fast 92 (Mustang Dyno)
This sole intent of this thread is to give feedback to those researching the heads and cam. I built this car as a streetcar, not a max effort build which is why I may get questions on why i didnt dump the exhaust or run a fast 102 or MSD.
Bottom line is the car runs hard.
Details:
PRC 227 62cc Pac .660
TSP Torquer V2 232/234 112 LSA
TSP 1.72 Roller Rockers
Fast 92/NW TB
Johnson ST 2126 LSR
Kooks 1 7/8 flowmaster y (catless) into 4" merge, magnaflow catback. (Full Exhaust)
Mustang Dyno (SD Tune)
445 RWHP
406 FtLbs
This is with stock fuel pump and injectors. Stock 10 bolt. Stock clutch. We spun it put to 6100 RPM as an FYI.
Thanks to the guys at TSP and special thanks to Timmy2Stage at Sound Performance for tuning the car.
Old 05-01-2018 | 07:41 AM
Jtm2085's Avatar
Was the car still making power at 6100? You said it was a street car but I probably would have ran it out longer?
Old 05-01-2018 | 07:54 AM
Agreed. The stock injectors couldnt keep up. At some point ill swap out to larger injectors/pump and run it out farther.
Old 05-01-2018 | 11:38 AM
Mavn's Avatar
"I MAID THEESE"
470 rwhp combo if spun to 7000
Old 07-01-2018 | 07:37 PM
bnastystuntz's Avatar
500 easy once u get proper fuel pump/injector and spin to 7 on a dynojet
Old 07-01-2018 | 07:54 PM
HCI2000SS's Avatar
That setup should peak around 6300 or so. Did you ever re-dyno or run it at the track?
Old 07-18-2018 | 07:26 AM
Thumbs down
Not yet. Life has gotten in the way lately.
Old 07-11-2019 | 05:38 AM
TBSOELS1's Avatar
any updates?
Old 07-28-2019 | 02:06 PM
Bob570's Avatar
^^ What he said.
Old 08-01-2019 | 11:41 PM
BADD SS's Avatar
Not a chance. I had a very similar setup, they don’t peak that much higher. 63-6600 tops. 500 rwhp isn’t easy... especially when guys are getting inflated dyno numbers, claim 500 to the tire and trap 117 mph.
The following users liked this post:
Outlaw_Maro (09-06-2019)
Old 08-18-2019 | 04:38 PM
jdwtx85's Avatar
we used prc 225s and polluter v3 cam and vengeance racing fast 92, ported ls2 tb, on a iron 6.0 in a c5z and made 494 with ls6 maf. need to get rid of the 85mm maf and maybe break 500
