Was that with cutout open? I'd expect a lil better if so! My M6 416 has been 10.9s a bunch & 10.8s usually @ 127 mph but best was a 10.84 @ 130 in cool air. All motor pump gas 9 inch
11.1 is my best et. 129 my best mph. It's all stock suspension wise. Tons of et to knock off with a better 60'
Its really apples to oranges as your 60ft is significantly better so you have a setup that can launch harder. He'd probably be close to 9s with a 1.4 60ft....and the 416 wasn't $1800😊
Really that turbo setup makes more power by 70whp so apples to oranges yes I have an NA setup that makes less! I'd say he'd be closer to 10.50 with a better 60 ft. I said not bad performance for an $1800 turbo kit. He needs tires I guess?
ET is largely a function of traction, and like I said you have more traction and if he was cutting the same 60' as you, the ET would be much less. Not that difficult to understand.
