All Motor 416 Ci Camaro On Pump Gas Bigggg Numbers!
Motot made good numbers. However after the dyno I made 1 pull on the street and the car died, now it wont crank or anything. Its not mechanical, its electrical. Im thinking the BCM Blew up (not Literally lol) ive tried everything I can. Dropping it off at the shop that tuned it and going to see if they can figure it out... Im stumped. Never had a car die mid pull lol ive checked grounds, tried different batteries, etc.., Even the gas gauge doesn't read now. lol lastnight it did, so the problem is getting worse... I really hope the whole car doesn't need to be rewired.
-Mavn
-Mavn
Sounds like a similar situation. Where something decides to "sacrifice" itself for the swap. Sounds unrelated to the motor itself.
I would say... The obvious first
1) Check all the fuses
2) if you have a spare PCM laying around... Plug it in. See what happens... Maybe blow that up as well.. LOL
-Mavn
-Mavn
hope it’s something simple.
You will pick up on top when you get the intake ported. Quite a few guys doing this, but Tony is the master if you can get in line with him. Phenomenal numbers again, and looking forward to seeing track times.
Moderator
Received 1,850 Likes
Your owned
#33
In for track results! My guess 10.1@138
#37
Moderator
Originally Posted by Mavn
Man yall have some High expectations for my driving skills lol its a Manual guys!!!
#39
Mavn, just BE the pro that you aspire to be..... BE the car... BE! (old Caddyshack reference....)
