NA SBE LS3 Record?
There is no drivetrain loss with a heavier clutch/flywheel. Just revs slower. It dynos the same.
Edit: I SHOULD say here there is no difference in TORQUE output with a heavier/lighter clutch. Since HP is a function of torque /acceleration, there IS a difference in HP with heavier/lighter clutches.
http://www.superchevy.com/how-to/eng...el-why-weight/
http://www.superchevy.com/how-to/040...l-information/
At 120 mph a 26" tire is rotating at a rpm of 1550. Now guys go to race brakes, light wheel/tires and pick up significant gains with parts rotating at 1/4 the rpm of the crank shaft.......think about it. Now that can be a much greater loss of weight by getting the weight out of 4 corners vs 1 crank. But it's turning much slower in comparison. The corner weights are also not getting a change in rpm to overcome like a clutch. They're more of a constant increase in rpm(acceleration) goin down the track.
Between a light clutch, light balancer and shortening the belt system you can be looking at removing 50ish lb of engine speed rotating weight......pretty significant imo.
Imagine dumping the clutch on a 60lb clutch assembly vs 19lb clutch assembly. Drivetrain shock is a huge problem with stick cars, a heavy clutch only worsens it. Its also insane that people believe 40lbs off your drivetrain wont free up power, if that were true then why are crank HP figures always higher then wheel HP figures.
Well if you're gonna try and use a heavy clutch the inertia from it needs to be utilized or it's a complete waste of energy. Now with that said there is no place in a performance car for a 60lb clutch. Gm simply used heavy *** clutches as a form of torque management.
Now here's the kicker. In bolt on form lazerlemons 60' was better with the light clutch(1.50 vs 1.58). Now there are other factors that can affect that (track prep, driving techniques) alot. But that's the results at the moment.
1. People who think they can drive stick but cannot in fact. Car is more likely to keep running vs stalling due to inertia.
2. Idle tuning. Heavier inertia makes idle more stable. Stock tube is not optimized per individual vehicle. Heavier clutch helps it get to a stable idle.
3. People who cannot drive and just hit the gas. Heavier clutch helps keep the tires planted vs new vette owner going sideways 3 miles from dealership and wrecking.
At the track the only advantage to a heavy clutch I can think of is the ability to absorb heat under high slip conditions. Once car is moving, advantage light clutch.
