2006 pontiac GTO
Old Jul 5, 2019 | 03:56 AM
Lawazita93's Avatar
Default 2006 pontiac GTO
Hey guys i dont know if its the right place to post but ive been having issues with my car on a dyno and im going nuts out here i would appreciate opinions and comments and ideas.
06 gto ls2
stock bottom end
ls3 prc milled and ported heads
gpi ls3 intake
staiess works 1 3/4 headers
svede intake
e85 injectors
walbro450
runs on e85
3in pipe
pat g custom spec cam 23x-25x .629 .615 lift
circle d 3800
spool
3.91 gears
1 piece drive shaft
built tranny 4l65e
ac delete
ps delete
weight reduction
mezzier electric water pump
slicks and front runners
well the car is a beast on the street runs good at the track
fastest at the track has been a 10.9 at 126 mph yet when i go put the car on the dyno its only making 376 hp to the wheels how is this possible, ive taken the car to 2 different dynos in the area and the both give me pretty much same results ive tried different tuners and both of them have told me that the car feels like something wont let the car open up the whole way takes a while to reach the powerband and yes in the videos you can hear the car, sounds kind of weird when it trues to open up like is something was just not letting it turn up do you guys think it can be me torque converter maybe its to tight? What do you all think, ive about done everything to the car except change torque converter
Old Jul 5, 2019 | 09:11 AM
Is that a single 3" exhaust? If so, there is your problem.
Old Jul 5, 2019 | 02:42 PM
Lawazita93's Avatar
No its its double with x pipe
Old Jul 5, 2019 | 05:42 PM
Dren's Avatar
I had a 496 stroker, 650 horse build that only put down 350hp on a dyno. But the car was a beast and would outrun >95 % of cars on the street. A dyno sheet is just brag rights but a 10.9 at 126 is way more brag rights. They said I had a loose converter. Sure it hurts but let a track grudge match do the talking..
Old Jul 5, 2019 | 09:33 PM
Lawazita93's Avatar
Thanks man ill keep that in mind ive done everything i can think of and had shops look into it i guess it just dosent like dynos its a beasst on the street though
Old Jul 6, 2019 | 12:15 AM
13qtr's Avatar
are you dynoing with the convertor locked or unlocked? A unlocked convertor will read low. My 'vertor can be locked at wide open... To show the difference, I dynoed with it locked and unlocked, back to back. Locked went 521/499. Unlocked went 487/436. A difference of 34whp and 63wtq
Old Jul 6, 2019 | 12:49 AM
Lawazita93's Avatar
Yeah its getting locked, i raced a 880hp turbo truck a while ago he runs 9.9 at the track has been his fastest i stayed about a truck length behind him so i mean i cant explain the numbers on dynos if the car acts diffrent on the street or track i guess it just dosent like to be on them
Old Jul 6, 2019 | 07:24 PM
30th t/a's Avatar
what's the race weight?
Old Jul 6, 2019 | 07:42 PM
Lawazita93's Avatar
Havnt weighed the car but a wild guess it be at about 3600
Old Jul 6, 2019 | 07:48 PM
13qtr's Avatar
If your asking me.... Mine weighs in around 3900
Old Jul 6, 2019 | 08:50 PM
rkupon1's Avatar
Have you guys been datalogging with it running good on the streets? Comparing em to logs on the dyno? I m aware they should be different, but looking for big inconsistencies
IIRC, typical H/C/I gto s are 450ish whp.
Old Jul 6, 2019 | 09:05 PM
13qtr's Avatar
I datalog all the time...what kind of differences? I wouldn't think they'd be much difference between the two. The tune doesn't know your on a dyno, it will spin up alittle quicker on a dyno. BTW...mine dynoed 441/412 all motor on the dyno, locked convertor..
Old Jul 9, 2019 | 02:53 PM
T.Man's Avatar
You have some items that aren't exactly dyno number friendly. Especially if you're dynoing with slicks. That aside, who cares what it dynos if it's running 10.90's at 125+
circle d 3800
spool
3.91 gears
built tranny 4l65e
Old Jul 9, 2019 | 05:44 PM
Jtm2085's Avatar
circle d 3800
spool
3.91 gears
built tranny 4l65e
How exactly do the front runners effect dyno numbers 🤷dum♂️. I just had to say it lol
Old Jul 10, 2019 | 01:26 AM
LilJayV10's Avatar
Internet....my 370whp car runs 10's......
Something is wrong. Why am I not making 500 to the tires? I want to make 500rwhp but if it's ok if it runs 12's
Somethings wrong.
Old Jul 11, 2019 | 01:46 AM
T.Man's Avatar
Your reading comprehension is lacking. I copied and pasted his list. Try rereading my post.
I swear to Christ. Between the OP and ********* like you, the internet and forums as a whole are turning into a **** fest of idiocy.
T.Man's Avatar
Somethings wrong.
Right? For ***** sake.
Old Jul 11, 2019 | 09:08 PM
LilJayV10's Avatar
here i condensed that for you.
www.ls1tech.com
Old Jul 21, 2019 | 08:43 PM
Chris25's Avatar
Nice times OP car sounds about right for the mods. How'd you like the switch to e85?
