Ls3 434
Old Oct 20, 2019 | 06:50 PM
lawrenq's Avatar
Default Ls3 434
I posted this in my build thread but I should have posted it here.
Here's my build.
ERL sleeved ls2 4.155 bore
Wiesco -8cc flat top pistons
Compstar 24x 4.00 stroke crank
Compstar rods
Advanced induction 280cc LS3 heads
Johnson 2116 lifters
Comp Cam BSR shaft rockers
Fast lshr intake
Speed engineering 1 3/4 headers
3 inch exhaust
Pat G custom cam 241/250 .630/615
Stock ls2 silver 90mm throttle body
Stock ls3 injectors
gto e40 ecm
gto t56
Ford 9 inch 3.50 gear ratio
Monster lt1s clutch
The engine has about 700 miles on it and it is being remotely tuned by Pat G. I installed the new fast hi ram and I haven't returned the car for the new intake yet.
Old Oct 20, 2019 | 07:32 PM
gnx7's Avatar
I'd say those are good numbers for a relatively mild cam.... plus the 9" eats up some power. That GTO T56 has awful gearing with the 2.97 1st.. you should look into the new T56 Magnum F style transmission with a 2.66 1st. Pretty much a direct bolt in aside from changing to a 31 spline yoke.
A 102/105mm throttlebody would free up a few more ponies.... plus 1 7/8" long tubes....
Old Oct 20, 2019 | 08:42 PM
Darth_V8r's Avatar
Moderator
You stand to set a new record for power gained via throttle body swap.
Old Oct 20, 2019 | 08:51 PM
lawrenq's Avatar
I plan to upgrade to the new f body magnum eventually and a 102 throttle body and better headers are planned.
Old Oct 29, 2019 | 08:44 AM
bortous's Avatar
When are you going to retune this with the new intake?
I want to see the final figures.
So far it looks not too bad.
Old Oct 29, 2019 | 10:38 AM
lawrenq's Avatar
Probably in a month or two, I plan on swapping to a 1 7/8 header and a NW102 throttle body. But I have some noisy gears in my rear end that I need to adress first.
Old Oct 31, 2019 | 02:38 AM
bortous's Avatar
Hurry and fix this issues.
My patience is wearing thin.
Old Nov 12, 2019 | 03:40 PM
lawrenq's Avatar
I'm installing a NW102 tb, ARH 2 inch headers and retuning for the intake, headers, and tb. Any guesses what it'll pick up
Old Nov 13, 2019 | 05:20 PM
mintws6's Avatar
Pat G is a great tuner!
Old Dec 2, 2019 | 05:51 PM
flash68's Avatar
New dyno numbers soon?
Old Dec 2, 2019 | 07:27 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
580+ RWHP (+40) on same Dyno
What is the LSA & Advance on your cam?
Old Dec 3, 2019 | 07:09 AM
lawrenq's Avatar
In a couple of weeks,
Old Dec 3, 2019 | 07:10 AM
lawrenq's Avatar
Originally Posted by navyblue210
580+ rwhp (+40) on same dyno
what is the lsa & advance on your cam?
114 + 3
Old Dec 5, 2019 | 03:24 PM
KW Baraka's Avatar
114 + 3
Cool.....because posting duration and valve lift tells you next to nothing compared to posting duration and LSA/advance.
TB + 2" primaries + retune = 50 HP peak and as much as 40 TQ after peak is my guess. A serious success in my book!
KW
Old Jan 2, 2020 | 09:41 PM
flash68's Avatar
Are you going to keep the factor LS3 injectors on there? At what level are they maxed out?
Old Jan 3, 2020 | 03:00 PM
Darth_V8r's Avatar
Moderator
Is it a couple of weeks yet?
Old Jan 3, 2020 | 03:30 PM
Jimbo1367's Avatar
I was asking the same thing a couple of weeks ago. I am sure many people are curious how well the new FAST MANI. Is going to perform .
Old Jan 3, 2020 | 04:57 PM
lawrenq's Avatar
It'll be awhile more likely two to three months. I'm in the middle of rewiring the car and swapping out a new rear end. I'm just as eager as you guys to see what this intake can do.
Old Jan 3, 2020 | 05:00 PM
lawrenq's Avatar
LS3 injectors are the same as ls7 injectors, I've seen people make 575-600rwhp with them. I'm going to log my next dyno pull the see what duty cycle they are running at.
Old Jan 3, 2020 | 08:55 PM
Darth_V8r's Avatar
Moderator
Hoover Damn!
