N/A E85 results
I've only messed with very mild blends on this car so far. Not totally surprised that you didn't gain anything from the timing... I just guess a slight bump from the increase in cyl pressure from the higher gas volume/pressure or whatever you get with ethanol.
Once we get the flex fuel sensor in. Ill retune it all and make sure its making the best power and we will try some different blends and see what that does. Ill try chaning the EOI and see if I can squeeze a few more out of it.
We just did this test real quick so see if it was even worth messing with. For his car now and for any future builds that may be more compression than what we would normally do for gasoline.
I've met Fran at some Holley EFI training a couple years ago...
I can honestly say he tells the truth and doesn't really give a **** what you have to say unless you can prove otherwise.
Also did 1.85 rockers, ported tb, it had a k&n cai, and put ls7 exhaust manifolds and cats with an X-pipe grafted to the stock mufflers.
Stock heavy clutch, c5z wheels and 295’s, all accessories, no underdrive, and needed headers in a bad way I think it would’ve helped no cats + long tubes. Lots more potential in the combo was just a fun side project. The car drove really well and the new owner is happy lol.
Wasn’t a record setter nor meant to be, just a point of reference for a mild NA car on flex fuel. It actually lost 5whp when I dyno’d it on E but picked up 15 ft lb down low. Had heavier tires on it and a different dyno day.
This car picked up anywhere from 7-15 through the pull. Id say an average of 10rwhp the whole way. Just because Fran couldnt do it, doesnt mean that its not possible.
On this car 10 more PEAK horse would have required atleast a cam change and we probably would have lost some power somewhere.
And it cost Zzracer less than $100. If he had only have gotten 7 peak horse power, that's still not bad bang for the buck when you already have everything else.
I dont know what to tell you other than yours and RPMSPEED's opinion just dont matter here.
Jon
Some cars will pick up literally 0, but the car runs cooler, you get lower charge temps in the cylinder and you don't ever have to worry about spark knock even in super high ambient temperatures. You don't need 100% E85 for these benefits either...30% already shows a big improvement and E50 is pretty much effectively the same performance wise.
At least 12:5.1 or higher some gains will surely be had.
There are also other benefits such as a more responsive throttle, and more torque low down and midrange and the engine runs noticeably cooler and more consistent.
maybe a little quicker too.
The gains are certainly much higher with boost.
Jon
I'm sorry that you posted on the internet and someone didn't agree with you.
I'm sorry that my experience is different than yours.
I'm sorry that that the people I've worked with, that are way smarter than most people on this board disagree.
I'm sorry others in this thread, and on the internet, we have had different experiences than you. Well that's ******* life.
If going E on a N/A build was worth it. You would hear about it just as much as you hear about going E on boost.
Honestly the only thing I'm sorry about is I bothered to post in here.
You probably picked up 10rwhp from a K&N too....
ok now I'm just being unreasonable...
