this car still just doesnt wanna make great numbers
#81
tony says pac 1207 set at 185 with yt rockers. These ones i have now are 200 on seat and just a hair higher specs after in comparisson to 1207
also just to give an idea, johnson does have maximum recommended spring pressures. He basically did say they are rather conservative, and have heard people running lots more and running for awhile. They are 185 seat, 510 when valve open. He said u can go a little over on either just not both, again he said he has more faith in them than that.
#83
extremely promising update, called johnson and in a nutshell, no matter what brand of 15/20 W 50 oil, several tests have proven oil temp needs to be at least 185 degrees for the oil to act like an oil and do its thing........me with my 205-210 coolant temp may see 165-170, maybe a touch higher while cruising, but no way am i getting 160 on the dyno.....i also asked him will your lifters be more sensitive than a longer travel lifter, he said for sure because the chamber inside the lifter is much much smaller, sorta forget what he said there......but basically said throw a 10/30 or 10/40 in there which will react proper with the lifters at lower temps.
my builder says forever ago he thinks he seen a thread that said quite a few people have used joe gibbs/driven break in oils with johnsons, unsure which ones, but have had bad luck with it.....thoughts on this? car has had probably 20 pulls now so i think we can throw an off the shelf conventional 10/30 in it for dyno purposes to see whats up.....builder says his previous shop used a lot of lunati lifters that were not short travels so the times they did use a 20/50 those lifters maybe could tollerate it a little more? idk either way this is the next move
The following users liked this post:
G Atsma (11-02-2020)
#85
For the clutch see if they can do a MPH view instead of an RPM view. Basically 1 to 1 final drive (4th gear with stick) the mph should be around say 115 mph using a 26.5 inch tall tire at 5252 rpm. If your tire is taller or you want to do it at a different rpm adjust accordingly. Beware of also dyno tire slip.
JoshHefnerX (04-09-2021)
JoshHefnerX (04-13-2021)
