Interesting 416 build comparo.....Dyno results of two long term MMS engine projects
Old 09-27-2020, 01:54 PM
Received 3,109 Likes on 2,424 Posts
C'monnnn man.... This is Tony we're speaking of here,, we all know he's the only one who can make cathedrals act like rectangulars when they need to.... lol
Keep knocking us out with your LS magic, Tony!
Old 09-27-2020, 03:01 PM
bortous's Avatar
It seems Tony is still selling a lot of cathedral heads because there are many people out there who find the characteristics of this head more purposeful.
Application dependant.
The following 2 users liked this post by bortous:
G Atsma (09-27-2020), tcgrmt (10-07-2020)
Old 09-27-2020, 07:26 PM
jhshnh's Avatar
Trust me, I’m not knocking the cathedrals. I have a pair of Tony’s MMS 220’s on my LS1. I’ll have it fired up very soon.
I’m just glad to see the theory that cathedrals don’t make big power on big cubes be proven wrong... once again.
“A ls engine doesn’t look at the intake port shape and decide whether or not to make power. It’s all in the overall combination.” Richard Holdener
The following users liked this post:
Old 09-27-2020, 08:19 PM
Originally Posted by jhshnh
".......It’s all in the overall combination.” Richard Holdener
^^^^^^^^^^Right here..... ^^^^^^^^^^
Old 10-02-2020, 03:19 PM
atlctsv's Avatar
Love the build break down and comparison across the two different setups! Thanks for sharing. Massive power out of a 416! Looking forward to more of this. btw, awesome pictures
Old 10-07-2020, 10:11 AM
tcgrmt's Avatar
This makes me smile, can't wait to get my 407 going with Tony's 235's and his custom cam.
atlctsv (10-07-2020)
Old 10-08-2020, 07:19 PM
nmass399's Avatar
Very nice, that’s good info for a build me and dad have coming sooner or later.
Old 10-09-2020, 11:55 AM
jmilz28's Avatar
Shockingly impressive yet not surprising. Been following your work for "a few" years and this is exactly what one would expect from you. Premium work and worth every penny. Well done sir, well done.
Old 10-12-2020, 09:52 AM
bortous's Avatar
Hey Tony,
I have been thinking, the 2nd engine which made 691 hp, what would the power difference be if you had put your ported fast 102 on there?
Would it be a 15hp loss I wonder?
Old 10-14-2020, 02:10 AM
LS1Tech Sponsor
Tony @ Mamo Motorsports's Avatar
Originally Posted by bortous
Hey Tony,
Peak torque would have been higher (10 or so Ft/lbs).....the lower and middle part of the curve would have been lifted from the very beginning of the pull, but after 6K the torque (and power) curve would have rolled over faster and it would have cost the customer 10 - 15 peak HP and would have been down 20 or so closer to 7500 RPM's which is the very usable current RPM I would suggest for optimal shift points.
Bort......its all laid out very well in this thread below where I do the exact test your inquiring about but on this particular engine (highlighted in this thread), the losses from the FAST would have been a little greater (its higher output and larger RPM appetite the reason why).
https://ls1tech.com/forums/generatio...orted-msd.html
In this application.....a light car with a Glide and a 5500 stall, the MSD was the clear winner here as the gains the FAST offers down low are meaningless. Once this car leaves the line it will grab second gear around 7500 and probably never see under 6K even on the shift. The MSD was absolutely perfect here but most guys reading this thread are probably better candidates for the ported FAST with heavier cars and 7K ish typical shiftpoints etc. The thread I linked above really lays it out in much greater detail....take the time to check it out
Regards,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
G Atsma (10-14-2020)
Old 12-05-2020, 02:08 PM
grubinski's Avatar
Very interesting post, thanks for posting! What are the cam specs on engine #1 ... you stated them for #2, but I didn't see them for #1.
Old 12-05-2020, 03:30 PM
  #32
241/246, .650-ish lift w/1.8 rockers. LSA is MIA..
I had to look too, it was between 2 pics.
grubinski (12-05-2020)
Old 12-05-2020, 03:37 PM
  #33
grubinski's Avatar
I'd like the LSA info to figure out the events. Nothing is more fun than bench racing camshafts. :-)
G Atsma (12-05-2020)
Old 12-05-2020, 04:22 PM
  #34
I'm with ya there!
Old 12-07-2020, 05:27 PM
  #35
DavidBoren's Avatar
If I had to guess the split on the 1st cam, I would say 114+2... based on other Mamo spec'ed cams that have been posted, and the cam Tony posted for the other engine... but this one needed some advance ground into it because road racing/early torque...
G Atsma (12-07-2020)
Quick Reply: Interesting 416 build comparo.....Dyno results of two long term MMS engine projects
