G8 - 408, LSA Heads, D1SC, E85
Old Jun 7, 2022 | 02:15 PM
kurazy kracka's Avatar
No idea what a glanzer tube is lol but if the IC isn't blocked then it sucks. 190* on 13psi is terrible, especially on a one gear dyno pull.
Prochargers dont start working well until they are spun over their "max rpm", its only over that arbitrary max when you are at peak RPM which is a tiny percent of the time. It also makes the whole powerband better spinning it faster.
this is the tubular crashbar, https://www.glanzerperformance.com/c...eservoir-mount
The 2 core procharger IC is only rated for like 550hp, it's pretty awful.
Old Jun 7, 2022 | 03:56 PM
ddnspider's Avatar
Originally Posted by kurazy kracka
wouldn't you want it to be pulling timing based on IAT's when seeing insane temps like that? Seems a bit unsafe to have IAT's that high even if it is on E, no?
Not on E. Pump gas absolutely.
Old Jun 7, 2022 | 09:05 PM
maybe I misunderstood him in just the fact that having a cooler denser air charge would gain HP? Going from 190* IATs to say 110* and with cooler denser air that aline will make a huge diff?
Old Jun 8, 2022 | 06:43 AM
ddnspider's Avatar
Yes colder air will make more power but that's not why your Dyno graph took a nose dive like SS said.
Old Jun 8, 2022 | 07:43 AM
well i have no idea why it did that then. I spoke with Pat G about a new cam and he said not to change it and then guessed that up top was caused by heat soak. Outside of that I don't have a clue
Old Jul 23, 2022 | 10:20 PM
No Juice's Avatar
Its a combination of the blower running out of steam, poor IC, and the LSA heads being untouched. That intake port wing is **** poor, get rid of it!
Old Jul 25, 2022 | 08:47 AM
SLOW SEDAN's Avatar
Agree, I've seen LS3 guys swap to the LSA head for boost and I'm like WTF are you doing?
Old Jul 25, 2022 | 09:00 AM
No Juice's Avatar
Here is some comparisons for ***** and giggles all on the same flow bench
Old Jul 26, 2022 | 02:21 PM
I have no desire at the moment to pull the heads off and have them machined.....IC will be done sooner than later, it's been so damn hot I haven't even wanted to drive the car recently.
Old Aug 15, 2022 | 10:28 AM
got new IC in, didn't get a chance to test it yet as it started raining. I went with the Treadstone TRV25O, 1500cfm and rated for 1000hp. Fit perfectly where the original ProCharger IC was. Also realized that my IAT's are reading too high at all times. Cold car, 80* garage and key in ignition, IAT's are reading 106* off the bat with car off (should read that garage ambient temp). I threw a new MAF in to see and no change. It is a LS3 MAF setup so my best guess is the scaling wasn't properly adjusted when being tuned. Dropping it off this week for some tune refinement.
Old Feb 14, 2023 | 08:10 AM
No Juice's Avatar
Updates ?????
Old Feb 14, 2023 | 03:53 PM
  #32
kurazy kracka is still around, so.....
Old Feb 21, 2023 | 08:39 PM
  #33
Updates ?????
Going back to the dyno Friday actually....taking it elsewhere and having Tim Haines tune it. Went for a revision to prior tuner and was not happy with the overall service I got. It's hitting the rollers at Tempest Racing. Only change is the IC so I don't expect much of a difference, mainly looking for better drivability.
I did find that the scaling was way off which was causing elevated IATs.
Old Feb 25, 2023 | 02:23 PM
  #34
Car made identical horsepower but was significantly lower on the torque. This was on a mainline pro hub dyno. I want to say the car did pick up power though as the injector duty cycle is about 10% higher. Haven't gotten to drive it yet much and still needs some final street revision which I hope to do tomorrow. ​​
