G8 - 408, LSA Heads, D1SC, E85
Car was on E70, made 13.4psi, and 19* of timing. Blower is maxed out with a 7.65 lower and 3.4 upper. Not crazy numbers but it looks like it'll be fun and a solid curve.
To be honest, dropping to a 3.25 blower or bumping up the crank to an 8" to see if it continues to pick up any will certainly be the "ok I'm all in now".
Damn good TQ too which the 4" stroke is helping.
Facts, almost every car that runs hard with a procharger is spinning them well above what the label says.
Realistically, I won't be making any changes until winter as I just want to enjoy it now, I've never driven the car as I bought it half way done and non-drivable n I finished it up. I considered just dropping the $40 to have Pat G spec a cam out for me too.
edit: just sent in a request to Pat G for a cam lol
Traction is the name of the game.
If you are worried, at all, about belt slip... I would go to the bigger crank pulley, rather than a smaller blower pulley. Spinning the blower faster will get you more, but you might want to upgrade the intercooler first.
More than 13psi means spinning blower past it's max RPM but I may go to a 8" lower with an ATI balancer this winter, also considered having the blower refreshed and turned into a D1X. Blower is at least 7-8 years old. Bigger IC, bigger lower, and D1X upgrade should make it real nice but even now 800whp is fine and I don't want to spend anymore $ at the moment lol
Prochargers dont start working well until they are spun over their "max rpm", its only over that arbitrary max when you are at peak RPM which is a tiny percent of the time. It also makes the whole powerband better spinning it faster.
