02 Z28 m6 boltons 358 whp 355 ft lbs
I have seen a good bit of power changing only the muffler on several vehicles over the years. I have seen even more power doing a full exhaust. Maybe a LS1 muffler flows better, but even my stock L03 TBI 305 1991 RS gained about 30 hp with a full exhaust from the head ports back using shorty headers. My Titan gained 15 whp swapping the stock muffler for a Magnaflow. My L31 Express van gained 12 whp swapping the stock muffler and tailpipe for a higher flowing Dynomax Ultraquiet 8.1L replacement muffler with its matching 4" tail pipe. It gained another 10 whp changing out the 70K mile GM 3" cats for 3" thunderbolt high flows. It gained an additional 15 whp changing up the air intake and using 4" tubing off the stock air box and a 4" MAF. Thorley tri-ys and the GM 196/206 @ 0.050 marine cam really woke that L31 up after it could actually move air into and out of it.
I too have a Titan, maybe I ought to put a muffler on that bad boy. The stock one is HUGE, I bet it weighs 40 lbs.
Here’s kind of a cool article where they test 2.5” vs 3” exhaust on a not so radical motor. 2.5” vs 3”
You went to the Dyno after a muffler change? I suppose your vehicles came with some the most restrictive mufflers of all times. Cat-backs seem to be good for something like 10-15 horsepower (or less) on just about every stock make & model I’ve ever seen, had, or heard about. This guy gained 8 horsepower with a cut-out. If a muffler was good for any horsepower (for his car) surely running open headers more or less would’ve made more than eight. Cut-out
This was in nearly 100F heat. Ran 14.20s in the Texas heat and 13.90s in October/November when it cooled off a bit.
It was quick for a 5,350 lbs truck with an open differential on 20" street rubber.
My 2012 made 296 rwhp and 388 rwtq on a Mustang Dyno with an Airaid MXP4, Magnaflow muffler and a Hypertech programmer set on the 93-octane tuning. It ran 14.60s with a muffler swap and a CAI. Ran 14.00s after the programmer. It made another ~10 rwhp with PRT 2.5" catless B-pipes with the stock manifold cats in-place and gained closer to 20 hp at ~5,500-6,000 rpm. It broke into the 13s with the B-pipes.
https://youtu.be/nyjcTTZ4wCQ?si=5BNtvAP5TQAMTauQ
https://youtu.be/yYDeLEA7apE?si=uFyY9rslY555uQeB
Right on target for ls1 t56 bolt on and tune with LS6 intake. Over 4:1 gears lower whp readings. My 98 ws6 has 4.10s and on a dynojet, they cost me about 10whp from I was told. Being a bolt on ls6 top end swap, made 393whp/386wtq. So had I kept stock gears for time being, would have hit 400whp. But wanted dd beater so throw on all the parts that makes a C5Z a "Z" vs base C5. Glad I did cuz LS6 cam doesn't kick in til 4500 rpms.
My 02 SLP Z t56 still has stock 3.42s. Full bolt ons minus e-w/p and has hi-flow catted y, 355whp and 371wtq. Tuned with the Diablo Predator when that was 1st released 20yrs ago. Still stock LS6 intake and factory tb (ported by Bo White). Never used a Dynocom dyno as I started with dynojets and keep with to compare with old dyno sheets... But your wtq should be more than 360wtq. Unless 4.56 gears throws off dyno's more than 4.10s ???
The following users liked this post:
G Atsma (01-03-2024)
Those are good numbers for sure, I'm about 25 rwhp less with my A4, similar mods but I have less gear, 3:73 and stock stall converter. Seems like the stick cars are always a bit more then the automatics when they get on the dyno.
G Atsma (01-24-2024)
Automatics have more internal friction or drag.
RMCosta (01-24-2024)
Roughly 15% for a Manual/7.5 rear and 18% for a 700r4/4L60E with a 7.5 rear. Pretty consistent across all years from the G-bodies to a 3rd gen to 4th gen and S10s on.
RMCosta (01-29-2024)
#32
The following 2 users liked this post by LilJayV10:
G Atsma (02-19-2024), Y2K_Frenzy (02-19-2024)
