605rwhp N/A stock SBE LS3 in a 5th gen
I finally hit the rollers with this solid roller N/A setup;
Cam motion low lash cam 239/253 720' 702' lift PAC springs 1529
T&D rockers 1.8
Stock SBE 50k miles,
RPS clutch carbon twin (25lbs)
Goertz1 custom fit manifold intake,
BBK 102mm TB,
Meziere EWP
2" Stainless Works LTs& HFC,
3" full exhaust Xpipe into Z28 mufflers,
MRR forged 19" wheels,
wildwood rear drag brakes,
Frankenstein Engine Dynamics LLC old TFS custom heads program,
11.33 CR, Cometic gasket
Pat G Tuning remote tune with no wideband, Vararam & JRE scoop,
short belt mod,
Fluid damper,
AMSOIL INC. Zrod 10w30 oil.
1 Bottle of VP oct booster in 91oct 1/4 tank
Thanks to my crew for all help and advices:
Tyler for the cam!!
Lazer
Hiosilver
Zack
Aaron for all the logistik
NUMBERS:
605rwhp/478rwtq with the sae correction. 623rwhp uncorrected. First run, I did 595 engine hot, then let it cool down, removed the AC belt and did 605rwhp.
Dyno sheet
T&D rockers 1.8
BBK 102mm TB,
Meziere EWP
short belt mod,
Fluid damper,
Tyler for the cam!!
Lazer
Hiosilver
Zack
NUMBERS:
Dyno sheet
Plus I'd say that my setup has the ingredients on paper to make that kind of power. But every dyno is different.
The following users liked this post:
Johnnystock (10-26-2023)
-crank scraper
-VAC pump
-more comp and E85/ race fuel
-bigger cam
-OTR CAI
I pretty much learned everything here, reading thousands of hours. Camaro5 and yellowbullet too. Too bad forums are empty now, they're the bibles for DIYers like me...
The following 3 users liked this post by Johnnystock:
Good heads, LLSR properly spec’s and RPM. Good things happen
DualQuadDave (10-27-2023)
Johnnystock (10-29-2023)
