my afr dyno
Old Aug 19, 2004 | 08:14 PM
  #61
MUSTANGEATER's Avatar
Tony is AFR going to release any smaller chambered heads? I'm looking for something in the 50-55 CC Range.
Floyd
Old Aug 19, 2004 | 08:27 PM
  #62
SlickVert's Avatar
I hopethat the AFR 225 Heads have small chambers!
Old Aug 19, 2004 | 09:33 PM
  #63
AINT SKEERED's Avatar
I have very mild heads with 2.02 int. valves and stock exh valves. I would love to put these heads on my moter to see what gain with the same 222/222-.566/.566 112 lsa cam would do with the afr's.
My heads only flow 256 @.500 and257@.600 but my 3726 lb car runs 11.6's @ 118 mph because the heads are barely opened up. These are not awsome times but for such a mild setup with only .015 shaved off the heads , they fall around 10.4 /1 compression and a baby cam.
I think Pdd's car is going to fly with this set up. and probably get better fuel milage along with less cyl. pressure (wear and tare)
I only like to change one thing at a time for this reason. Oh , WHat gears do you have Pdd? And with the cats, that is awsome hp. That cam should have more exh. duration for cats should'nt it?
Old Aug 19, 2004 | 10:05 PM
  #64
The 225's and 205's start as the same casting so I doubt they will. I'm hoping AFR will release a casting w/ smaller chambers though.
Old Aug 20, 2004 | 02:51 AM
  #65
jrp's Avatar
jrp
SN95 Director
Tony is correct but there in lies the difference between a proper setup and one just bolted together. its also the same reason shop cars dyno considerably more then a regular user who just throws on the same parts. i think results like PPD's will be common as long as people just throw **** together.
Old Aug 20, 2004 | 03:52 AM
  #66
pdd's Avatar
pdd
i guess non of u guys read what i said before. i didn't want to flycut my pistons. if i milled my heads i would of had too. its not like i just "threw **** together".
Old Aug 20, 2004 | 03:55 AM
  #67
pdd's Avatar
pdd
Old Aug 20, 2004 | 10:30 AM
  #68
foff667's Avatar
LS1TECH Sponsor
lookin at that sheet you still have that weird hump...i still think theres something up...i think the last time i mentioned it you had said something about the clutch er something...i have a hard time believing it still though. JMHO
Old Aug 20, 2004 | 06:48 PM
  #69
pdd's Avatar
pdd
i was told its the cam
Old Aug 20, 2004 | 07:36 PM
  #70
Slowhawk's Avatar
LS1Tech Sponsor
The dip is the setup somewhere.I tuned all around it and the dipping affect would not change no matter what.The printout gragh makes it look huge by the way it's setup.I've seen a few 114 duration Cams do that.
Old Aug 21, 2004 | 03:18 AM
  #71
kumar75150's Avatar
I didnt read all the posts but
1) you are prolly giving up around 15hp in compression
2) your gears are probably costing you close to 10hp
3) Tony had a EWP which is worth 5-10hp
Just adding those things up gets you over 460rwhp with a small cam. Thats pretty solid IMO.
Old Aug 21, 2004 | 04:30 AM
  #72
jrp's Avatar
jrp
SN95 Director
he has an EWP, and just about every other dyno improving mod including an aluminum flywheel..
Old Aug 21, 2004 | 05:45 AM
  #73
PREDATOR-Z's Avatar
The AFR used on the Vette were 11.2 CR, also let us not forget that vettes dyno notoriously higher than f-bodies with equal setups.
Cam has a lot to do too.
Had you swapped AFR with same CR, you would have picked up another 12>15 ponies.
that would put you at around 450 horses. That IMO is very respectable with a head that has 205 runners.
Also Tony dynoed his set up in Cali and not in Mass. and on different dynos.
To many variables. Need to compare apples to apples.
can't wait for mine (AFR's)
Old Aug 21, 2004 | 09:24 AM
  #74
max's dad's Avatar
I was always under the impression that the F car dynoed better. Solid rear wastes less that the IRS.
Old Aug 21, 2004 | 09:26 AM
  #75
mike m's Avatar
pdd The good thing is you have a better quality head that has room for imporvement for the future. There is more work that can be done to the afr heads. The patriot heads you had were notorious for sinking valve seats and loosing power due to oil consumption. Now if you want to spray the car or even add a blower you can do it with confidence that you wont lift a head. The AFR heads seal much better then stock heads. Good luck with your car im sure you'll see a difference in performance.
Old Aug 21, 2004 | 09:27 AM
  #76
mike m's Avatar
dont forget the vette has that dyno stealing torque tube. Butt pdd has a vette anyhow so what does it matter. right???
Old Aug 21, 2004 | 03:59 PM
  #77
LS1derfull's Avatar
I think 20 hp is a good gain thru cats with this cam. Most of this is from head difference since old TB was 85mm allready. Swapping out LS6 style ported heads with much more compression, and gaiining everywhere in power is a tall order for any head. As mentioned earlier anyone swapping heads when they make over 400rwhp allready had better not expect 50 to 70hp gains, at least not without cam change also.
Old Aug 25, 2004 | 06:23 PM
  #78
jaberwaki's Avatar
what was the total cost...
hmmm...
2100 for the heads 1100-1300 back for the sale of the pp's
800 for lsx 300 back for sale of ls6
600 for tb 300 for sale of 85mm.
at the high end he only spent 1800 at the low 1600.
looks like 40-45rwhp gain after adding the loss for compression
i know alot of people that would spend 1600 for 45 hp
Old Aug 29, 2004 | 05:06 PM
  #79
92SilverSHO's Avatar
and one final thought. im the man!
Old Aug 29, 2004 | 05:37 PM
  #80
max's dad's Avatar
No one from that dump is the man! Go Owls...
