my afr dyno
Old Aug 18, 2004 | 01:29 PM
pdd's Avatar
pdd
Default my afr dyno
i was hoping for better but these numbers are at 66cc with the fast 90 and 90tb with a corsa exhaust resulted in 434.2rwhp and 402.3rwtq from 413.6rwhp and 388.3rwtq. the last run on there was with PPls6 style 59cc heads and an ls6 intake with an 85mm bbk TB.
2100 for heads
800 for intake
600 for TB
all for 20hp. is it worth it???????
http://www.picturejudge.com/memberpi...s/IM000378.JPG
edit: no cutout through cats
Old Aug 18, 2004 | 01:40 PM
1fastWS6's Avatar
Eeeek. Not what I would have expected. Lets see what it runs at the track though......
Edit....do you have cutout on the Corsa? If not, you probably need one BAD!
Old Aug 18, 2004 | 01:43 PM
pdd's Avatar
pdd
[QUOTE=1fastWS6]Eeeek. Not what I would have expected. QUOTE]
thats what i said
Old Aug 18, 2004 | 02:07 PM
MYBLKSS's Avatar
Well you dropped compression by about a point right? So I going to say thats worth about 10hp. When factoring in the drop in compression you are looking at 30 hp over an already pretty stout setup. I think its a nice jump all things considering. Was it worth it? That is up to you my friend. Either way congrats on the new setup.
Old Aug 18, 2004 | 02:12 PM
KGSloan's Avatar
that's not a bad gain. still i would've expected a little different.
what i'm really curious about is your curve. both your setups look like they have the same, really eratic torque curve. is there a reason for that? i would think both setups would've had a much smoother curve.
edit: was the car tuned with both setups?
Old Aug 18, 2004 | 02:18 PM
pdd's Avatar
pdd
must be the cam and yes the car was tuned for both setups
Old Aug 18, 2004 | 02:23 PM
2MCHPWR's Avatar
what is approx compression ratio with 66cc?
Old Aug 18, 2004 | 02:32 PM
CHRISPY's Avatar
Congrats on the numbers but it seems that the PP heads did ok considering you added intake, 90mm and tuning with the AFR's.
This is why I tell people if you dyno 400-420RWHP with heads/cam dont bother changing heads. It is a waste of money.
If you added the LSX and 90mm to the PP heads you would see a similar gain with tuning imo. (430 range easily)
Old Aug 18, 2004 | 02:33 PM
OWENMUSTANG's Avatar
looks like the only things different than what's on tony's are
comp.
cam.
cat back.
40HP difference between the 2 cars....
what kind of head gskt are you using?
Old Aug 18, 2004 | 02:38 PM
MYBLKSS's Avatar
72.27cc = 9.1 CR
71.71cc = 9.2 CR
71.05cc = 9.3 CR
70.59cc = 9.4 CR
70.03cc = 9.5 CR
69.74cc = 9.6 CR
68.91cc = 9.7 CR
68.35cc = 9.8 CR
67.79cc = 9.9 CR
67.23cc = 10.0 CR
66.67cc = 10.1 CR (stock LS1 head spec)
66.11cc = 10.2 CR
65.55cc = 10.3 CR
64.99cc = 10.4 CR
64.43cc = 10.5 CR (stock LS6 head spec)
63.87cc = 10.6 CR
63.31cc = 10.7 CR
62.75cc = 10.8 CR
62.19cc = 10.9 CR
61.63cc = 11.0 CR
61.07cc = 11.1 CR
60.51cc = 11.2 CR
59.95cc = 11.3 CR
59.39cc = 11.4 CR
58.83cc = 11.5 CR
58.27cc = 11.6 CR
11.4-10.2= 1.2 Drop in Compression
Old Aug 18, 2004 | 02:41 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Hmm.
True, the cc difference does not provide an apples to apples comparison.
Nevertheless, I would have expected a bit more than what resulted.
20hp and 20tq is significant, so enjoy your newfound power.
Take it to the track now.
Old Aug 18, 2004 | 02:52 PM
CHRISPY's Avatar
Originally Posted by SouthFL.02.SS
Hmm.
Significant for a intake swap (LSX) but not heads, intake and T-body imo...
Old Aug 18, 2004 | 02:56 PM
!LS1 11 Second Club
True.
Old Aug 18, 2004 | 02:59 PM
Slowhawk's Avatar
LS1Tech Sponsor
The heads are good.He was running 11.2-1 cmpression with the patriots then took them off and used box stock AFR's and added the 90mm intake and still gained good power everywhere.Now if he just had stock heads there would of been a huge gain. I personally like these heads.
The torque curve is the setup.I tuned all around it and the curve looked the same everytime.Of course the dyno graph setup makes it look more dramatic.
Old Aug 18, 2004 | 03:12 PM
gomer's Avatar
I like making big numbers as well as anyone.. but holy ****, that much money for a 20hp gain and not even that much on the torque numbers (where these heads are supposed to shine)?? And not to mention that for $2100 he got a set of heads that in my opinion need another $1000 spent on porting to be optimized. I'll wait for some more independant results like pdd's before I puke up the money for a set of these.
Old Aug 18, 2004 | 03:16 PM
hard to read the sheet.. looks like torque is up across the board.
full point less compression, using a 228 cam.
doesn't seem too bad of a gain imo.
Old Aug 18, 2004 | 03:18 PM
BTL FED's Avatar
I dont think that is bad, you picked up good power and torque, while losing almost a full point of compression. Plus if you ever decide to spray the car you have nice 3/4" decks to help keep the heads down. Also what Maf and lid are you running, if you are running a stock maf, then a 90mm TB isnt really helping much as it can only flow are much air as the smallest restriction.
Old Aug 18, 2004 | 03:30 PM
2MCHPWR's Avatar
why did you want the lower compression? how much does it cost to get the compression back up to about 11:1?
Old Aug 18, 2004 | 03:33 PM
Ravenous T\A's Avatar
Wonder what Tony's car compression ratio was on his Car? He did 470rwhp, thats a far cry from Pdd numbers, wonder why there is some much difference in power? That and I think Tony was using a 224 cam or close to it and got 470?
Old Aug 18, 2004 | 03:37 PM
CHRISPY's Avatar
Milling is only around 100 bucks but you have to be concerned with PtoV clearnace and valvetrain geometry/setup.
