MTI Comp Stealth II cam Stage I trans and retune
Originally Posted by TT_Vert
what are the specs of this stealth 2? is it actually "stealth" can you tell the car has a cam? How is the idle? in drive and park?
Dave
Dave
224/220 581/581 116LSA
Drivability is good, no obvious lope. Do a search, The Colonel has a sound clip up somewhere.
What are the advantages of the stealth II cam over the stealth I. I ask this because I have the heads off of my car and I ordered the stealth II cam to put in with the new heads. The thing is, I recieved the cam today, but it's the stealth I. I really want to get my car put together, so should I install the stealth I or hold up until I get the cam I ordered?
Stealth 1 is a 220/220, .581/.581 115 lsa (straight up)
It is within the same power range of the stealth II but that power comes on a little earlier. The extra intake duration of the Stealth II 224 VS 220 will give you a little more power (5rwhp, if so)
I decided to hold off on putting the cam in until I get the stealth II that I ordered. I guess I would have put it in if I knew it was only going to be about 5rwhp difference, but I figured it would be a little more than that. Oh well, I've only seen dynos from the stealth II so at least I have that to back it up, I've yet to see one of the stealth I.
