SLP 402, AFR 205, TSP MS3, Rapid Tuning
Does it smoke while driving around or getting on it? Or, did it only smoke on the dyno? The reason I ask is, when I installed my H/C and brought it to FMS to get tuned by Allan, my car smoked on every pull. granted, my car has 80k miles so he basically said it was normal. Was my reaction. On the way home with my buddy following I ran it throught the gears and no smoke. It hasn't smoked since then and I really don't know what caused it. If I remember correctly, it smoked the most when he let off the throttle at the end of the pull. Anyway, good #s and good luck with the smoking issue.
Shorty Director
I am also concerned with the smoke. That is not a good sign. My car does not smoke. You might get a puff from too much fuel on the initial hit while I am walking away from someone, but thats about it. My car has a nitrous tune so my a/f is on the rich side. I have seen and heard about a few cars in Florida having similar issues. They all dyno'd high and they all broke down soon after.
Called SLP today. Kevin, who I believe is the Sales Manager, is looking into it. He took info on part specs and tuning to talk to their engine builders. With this being the first "real world" results, one would think they would want to set a good precedent and take care of a defective product. Stay tuned...
I followed Mikey on the way home in my car. He punched it once and left me in a mushroom cloud.
Would having cats versus not having cats make it smoke more/less? Mine smokes right when you hit it on the dyno, like a puff shoots out. The exhaust is very pungent, without the cats, its easy to tell its uncatalized. Maybe the ORY has something to do with it and the tune?
#32
LS1TECH Sponsor
#35
Let me also say that oil smoke is bad. My first JPR 388 built motor smoked like a ****, also only when I got on it. The car put down 478rwhp on the dyno, but never performed at the track. Then it came apart in a big way (boom!), twice. I hope that is not the case for you, but I would be very concerned. Break-in miles do not matter for smoking, it will smoke right off the bat or it wont. Mikey built my new motor with an ARE shortblock, and it does not smoke, after almost no break-in before going on the dyno.
One suggestion is that if you are using synthetic oil, change over to dyno oil...the rings wont seat properly with synthetic. You can also try a heavier oil, that may help but probably wont solve the problem
#38
Man I'm definately NOT going with SLP after reading this thread.
#39
My experience in building motors is only with small motorcycle motors.... but it's been my understanding that ANY smoke early on in an engines life is bad-bad-bad. ... If rings were going to seat properly, they would have during the first few minutes of the motors life.
What do the plugs look like?
