patriot h/c dyno
I had Mti install the h/c package and tune the car. My dyno numbers are as follows with the stock throttle body and taylor wires.
uncorrected... 78.8 degrees corrected....
407.8hp/388.5tq..........413.3hp/393.7tq
A week later i added the Mti Polished Throttle body and Msd wires and here are my new numbers,,(also fixed a tps problem from the first dyno)
uncorrected....61.9 degrees corrected....
431.5hp/396.2 ...............404.3hp/371.3tq
the corrected power levels seem very low... anyone have any thoughts????
Patriot seemed very persausive that this kit made tons of power, but i dont see it.. or am i missing something .. or is some thing wrong..
i'll try to get the charts posted if i can get to a scanner. charts seem pretty smooth except for a very small amout on scribble past 6100, but its seems much more clear after the wire change and tps fix...Like i said just seems low after seeing cam only cars push 400-410. any thoughts would be appreciated.. thanks
just my .02
before h/c on nitto drags... 3k launch.. no powershift... 12.40@112mph...1.818/60ft.
After h/c...nitto drags...no powershift...3k launch.(car spins if any higher,waiting for ets and prostars)...made 3 passes, 1st pass was 12.2 after bogging car, 2nd was a 12.0 and 3rd was...11.992@118.82...1.871/60ft
any ideas?
FWIW my dyno #'s were about the same 407RWHP one time and 417 another time. The Best V8 Stories One Small Block at Time
450/420 with the 10 bolt and 441/412 with the 12 bolt
I would be very happy if i made that much rwhp.... is that corrected power?
Mti had no suggestions. Just stated that i should try to dyno it on a warmer day so the correction factor isnt so bad. Uncorrected i made plenty, but i lost 27 rwhp after corrected. Mti said i made good power for a h/c car. I disagree though. I think it may be in the tuning if thre is any power left to find. I do have confidence in mti's tuning, but they tuned it with a wire falling off anmd the tps falling off. The tech that installed the h/c seemed to forget to install them correctly. After the car got off the dyno, it would barely run. I fixed the wire and tps, but the tuning is still the same. Im not sure if it would change much if any, but that is my only guess.. other than that i guess this is all it will make.....
Regardless, with a normal weight SS trapping close to 119mph on drag radials is pretty good. When I had the TR224 cam and Patriot LS6 heads, mine trapped 118.6 at 3610# raceweight on ET Streets with a 1.6x 60' time. It dyno'd 415 rwhp/404 rwtq at the time.
so, 62* is 15* under what SAE is. and then whatever the humidity was recorded at the time has to be corrected to 0%. and humidity is still where the correction problem is.
