New Race-Prep engine package developed & Dyno tested!
Old Mar 28, 2005 | 01:12 PM
Race-Prep's Avatar
Suspended Sponsor
Default New Race-Prep engine package developed & Dyno tested!
Well, we finally got the new 418ci engine on the dyno Friday. The thing ran real well! We used the Fast intake with the 90mm throttle body and our own custom grind cam on a 108LSA with over .650" lift but still retained the hydraulic lifters so this is a true street worthy engine. As for the heads they are our own developed 6.0L castings flowing over 330cfm from a small 218cc runner. The compression is 13:1 which is a little high for CA fuel but you guys with 93 might be able to make it work or just a splash of race gas and your good to go. This engine made huge torque across the board, at 3700 it has over 500LBFT of torque and peaks at 585 torque! The horsepower is no slouch either as it produced 630 hp and remember this is a budget built engine using the cast iron block! We are very happy with the numbers and are anxious to see how it does on the track, the area under the curve of this engine is HUGE so it should do real well!
Thanks for reading!
Bryan Wolter
Race-Prep Performance Engineering Inc.
Old Mar 28, 2005 | 01:19 PM
ONEBADWS6's Avatar
are these engine dyno #'s?
Old Mar 28, 2005 | 01:21 PM
Nine Finger 02 Z28's Avatar
Thanks for reading!
Bryan Wolter
Nice #'s Bryan.Was that to the wheels ? and are you guys doing your own tuning now?And how much for some Dyno Time?
Call me if you want,and if you don't have my # PM me for it.Thanks Jason.
Old Mar 28, 2005 | 01:48 PM
Race-Prep's Avatar
Suspended Sponsor
These are Engine dyno figures so about 45-50 or so lost to a six speed at the wheels. Either way the torque is still great!
-Nine finger, Yes, we are doing our own tuning here now and actually came across an excellent tuner who I have seen no equal thus far so he is very good, if the car has it in it, he can get it out of it!! Feel free to give us a call or if I don't hear from you I will get in touch with you.
-Bryan
Old Mar 28, 2005 | 02:36 PM
xfactor_pitbulls's Avatar
-Bryan
More like 100 to the wheels lost. Numbers are still good for what would be a fairly cheap build. Congrats.
Brandon
Old Mar 28, 2005 | 02:46 PM
Race-Prep's Avatar
Suspended Sponsor
Actually the manuals don't loose that much they are in the 50 range. I have seen back to back tests. The autos however are much higher, more like 80-100 with a loose converter.
Old Mar 28, 2005 | 07:10 PM
VINCE's Avatar
Shorty Director
Very stout #'s... Can you tell us the bore and stroke of this iron block?
Old Mar 28, 2005 | 07:27 PM
Race-Prep's Avatar
Suspended Sponsor
The engine consists of fairly normal pieces, the bore is 4.030", the stroke is 4.100" and the rod is a 6.125". Basically an Eagle crank, Scat rods, Wiseco Pistons and Clevite H-series bearings. The trick stuff is in the heads and cam combo and all the little tricks in the shortblock, every little bit adds up.
-Bryan
Old Mar 28, 2005 | 08:33 PM
VINCE's Avatar
Shorty Director
-Bryan
Very impressive indeed.. Thanks for all the information..
Old Mar 28, 2005 | 08:59 PM
LTLHOMER's Avatar
Nice numbers!
Old Mar 28, 2005 | 09:05 PM
Got Me SOM's Avatar
13:1 compression needs just a splash of race gas...
Old Mar 29, 2005 | 12:57 PM
RAMPANT's Avatar
Great numbers!
I heard that they had some problems with the Eagle 4.10 crank!
I had ordered it for my set up and now I have had to change to a Callies 4.125 and 6.200 rods.
Did you here anything about this?
I'm hoping to get 85% of your results with my 415 LS2.
Again great numbers!
Rampant
Old Mar 29, 2005 | 05:20 PM
xp3nd4bl3's Avatar
Moderator
Bryan, nice work, I've always sworn by your heads. Why go with such a small runner on a good sized motor?
Old Mar 29, 2005 | 07:19 PM
Race-Prep's Avatar
Suspended Sponsor
MIDRANGE TORQUE!!
LOL...
500+LBFT at 3500 RPM and 585 peak will get you moving very quickly, especially in a manual trans where you don't have that converter to multiply torque.
By the way how is the Camaro running these days?
-Bryan
Old Mar 29, 2005 | 07:23 PM
Race-Prep's Avatar
Suspended Sponsor
Originally Posted by RAMPANT
Great numbers!
Rampant
The Eagle cranks are fine but they won't release them to the public because average pistons won't clear the reluctor wheel and most guys I have a feeling don't mock assemble their engines and they have had problems...Good thing we do mock 'em all up!
-Bryan
Old Mar 29, 2005 | 10:44 PM
xp3nd4bl3's Avatar
Moderator
Bryan, the Camaro's running great, even with these three year old Race-Prep heads. I'm just waiting to spray too much and blow up this 6.0L block so I can replace it with a big RP motor.
Old Mar 30, 2005 | 08:29 AM
Race-Prep's Avatar
Suspended Sponsor
Well, you know where to find us! We would be happy to make that thing destroy all who oppose!! (LOL). Keep in mind we are doing our own dyno testing and VCM tuning as well.
-Bryan
