Everyone please post torque @ 3000-4000
Old Apr 5, 2005 | 08:20 AM
SideStep's Avatar
Dynojet SAE corrected
RPM
2000 303 ft/lb
2500 334 ft/lb
3000 340 ft/lb
3500 345 ft/lb
4000 377 ft/fb
Peak 407 ft/lb at 4650rpm
Old Apr 5, 2005 | 09:52 AM
v8maro's Avatar
3000 - 275ft/lbs
3500 - 345ft/lbs
4000 - 355ft/lbs
peak 370 @ 4750
346ci
Patriot Performance S2 5.3L - TSP 232/228 112lsa
Old Apr 5, 2005 | 10:00 AM
blakester's Avatar
My 03 cobra. Not an f-body but stock heads.
Old Apr 5, 2005 | 10:31 AM
777's Avatar
777
that's crazy ^
Old Apr 5, 2005 | 11:41 AM
Ryan02SS's Avatar
Patriot 5.3Ls @ TR224 112LSA 214cc intake port
2000rpms 301rwtq
2500rpms 325rwtq
3000rpms 352rwtq
3500rpms 361rwtq
4000rpms 370rwtq
4500rpms 379rwtq
Peaks 391rwtq @ 4900rpms
My biggest gripe about my setup is the flat spot in rwtq from 3000-4200rpms, it climbs very slow in that range and picks up fast after 4200rpms. Lowend and peak torque are very nice.
Old Apr 5, 2005 | 12:24 PM
silent1's Avatar
AFR 225's w/ G5X4
3000-450RWTQ
3500-470RWTQ
4000-460RWTQ
Old Apr 5, 2005 | 12:29 PM
txhorns281's Avatar
TR 230/224, Stock 853 Heads, Stock Bottom end:
3000 350
3500 375
4000 385
Old Apr 5, 2005 | 02:05 PM
Brian Tooley Racing's Avatar
Originally Posted by silent1
AFR 225's w/ G5X4
3000-450RWTQ
3500-470RWTQ
4000-460RWTQ
Not really looking for 427 A4 numbers, I think Brent should have specified H/C cars with a stick transmission, as we have seen A4 H/C cars hit 500 RWTQ. Thanks for the reply though, are those torque #'s with the convertor locked?
Old Apr 5, 2005 | 02:15 PM
LSUxBlake's Avatar
3500 - 378
4000 - 393
A.S. Stage II 5.3
FMS F11 (228/230 .576/.595 112)
Old Apr 5, 2005 | 05:15 PM
Viper's Avatar
Dynoed in Ohio in 90 degrees:
3000 - 325
3500 - 350
4000 - 365
Dynoed at JD's in Pennsylvania in 40 degrees
3000 - 350
3500 - 370
4000 - 390
Go figure on the dyno discrepencies.
JPR S2 heads
TR224 112 cam
Old Apr 5, 2005 | 05:20 PM
NHRATA01's Avatar
AFR 205s, MTI T1 (.558/221)
3000- 350
3500 - 360
4000 - 370
Old Apr 5, 2005 | 10:10 PM
  #32
BrentB@TEA's Avatar
Originally Posted by jrp
isnt this thread suppossed to be a corrilation between the tq at those specific rpms and the port volumes of the heads?
as is this thread is just another "dyno" thread.
before the wide use of the AFR 205 heads the only note worthy setups i recall are the TEA 2.5 ls6 and custom FMS cam, a few LGM combo's using ls6 heads and x2/x3 cams. i must say, that TEA/FMS combo had the most beautiful tq curve i'd ever seen; 350rwtq @ ~2800 and 400rwtq @ 3500 .
do you remember the port volumes on those heads brent, i seem to remember them around 231cc.
they were pretty close to that. Our new port is more like 224-225cc's and flows better.
the biggest size differences will be between an AFR 205 and some of the other ported heads. I am just seeing if there is a huge torque gain with the small cc runner like we have all been told. so far I am not seeing it.
Old Apr 6, 2005 | 02:28 AM
  #33
LSs1Power's Avatar
Bone Stock:
3000RPM 285rwtq
3500RPM 290rwtq
4000RPM 292rwtq (peak)
LID+ LM catback:
3000RPM 305rwtq
3500RPM 315rwtq
4000RPM 320rwtq
Peak at 4500RPM making 336rwtq
LID+LM+FLP headers:
3000RPM 330rwtq
3500RPM 345rwtq
4000RPM 355rwtq
Peak at 4500RPM making 363rwtq
LID+Hooker catback+FLP+FM7 Cam:
3000RPM 330rwtq
3500RPM 355rwtq
4000RPM 372rwtq
Peak at 4200RPM making 378rwtq
LID+Cutout+FLP+FM7 Cam:
3000RPM 335rwtq
3500RPM 360rwtq
4000RPM 375rwtq
Peak at 4200RPM making 382rwtq
And just for the hell of it
8rib D-1SC+FLP+FM7 Cam:
3000RPM 400rwtq
3500RPM 440rwtq
4000RPM 490rwtq
Peak at 4400RPM making 499rwtq
Old Apr 6, 2005 | 10:10 AM
  #34
Flareside's Avatar
"torque down low", to me, means how the engine runs from idle to say 2500 or so, not something that's measured on a chassis dyno. I.e, how does the car pull from 1000 rpms in 4th gear, something that happens all the time in normal street driving. This thread seems more like a midrange discussion.
Old Apr 6, 2005 | 10:20 AM
  #35
ty_ty13's Avatar
7 Second Club
this may be but if your cars rpms are below 3xxx you wouldn't be in your "racing power band" right... so i ask why does it matter how much HP/TQ you get at 3000 and below.
this would be false if you have an A4 with no Torque converter
but i would think if you had a M6 you would ATLEAST leave at 3000ish.
I guess im just curious to y the down low torque is so important?
as for me im looking for 3000+ power.
could some one help me understand the big HUB-BUB
Thanks,
Tyler
Old Apr 6, 2005 | 10:36 AM
  #36
lilbuddy1587's Avatar
he asked for everyone WITH AFTERMARKET HEADS AND A CAM TO POST THEIR NUMBERS BLAH THROUGH BLAH RPM, NOT WHAT YOU DID WITH A BLOWER, CAM ONLY, OR BONE STOCK. Jesus christ people, read and quit acting like a bunch of show boating nubs.
Old Apr 6, 2005 | 10:53 AM
  #37
Flareside's Avatar
Thanks,
Tyler
Not every car is track-only, the majority of us drive on the street, sometimes under 3000 rpms...
Old Apr 6, 2005 | 10:59 AM
  #38
silent1's Avatar
I figured as much. The reason I posted was because I don't recall any 427's having peak torque under 4000RPM's. I'm used to seeing them at 4300-4600 and mine came in at 3400RPM's with the "small" ports of AFR's.
Old Apr 6, 2005 | 11:00 AM
  #39
ty_ty13's Avatar
7 Second Club
right, mine too is a daily driver. but if the hp is at a low rpm it wouldn't be very usefull. becaue WOT your Rpms shoot up and you are now longer at low rpms... I'm truthfully not trying to be a jerk or any thing i'm just trying to understand how you guys see it.
TIA
Tyler
Old Apr 6, 2005 | 11:28 AM
  #40
777's Avatar
777
and your post was very productive and on topic...if you are going to critique others you might want to at least post up your numbers of your heads/cam car (if you have one) which it doesn't look like you do...so i suppose you just flamed yourself good job
