Everyone please post torque @ 3000-4000
3000 xxx
3500 xxx
4000 xxx
cylinder head used and cam
Thanks for your time and input
3000- 190ft/lbs
3500- 225ft/lbs
4000- 265ft/lbs
peak at 4900rpms- 365
graph is here http://img.photobucket.com/albums/v4.../dynograph.jpg
3000 xxx
3500 xxx
4000 xxx
3000 - approx. 325
3500 - approx. 340
4000 - approx. 360
Max is 366 around 4900
3000 xxx
3500 xxx
4000 xxx
This is with heavy drivetrain. (Heavier than stock driveshaft, 65lb wheels/tires, 12 bolt/4.10s) My numbers might have been better had I not had a busted clutch during this pass.....
3000- 310rwtq
3500- 357rwtq
4000- 370rwtq
Peak torque 405rwtq @ 5500rpms.
2500-310 ft lbs
3000-355 ft lbs
3500-370 ft lbs
4000-375 ft lbs
peak tq at 4750 405 rwtq
i like the way u added taht 2500rpm 310tq
... hope my f14 does the same, futral kicks ***..im having them port my 241 casting heads im sending them... im going to ask him to add more power everywhere including down low, im sure he can do it lol
as is this thread is just another "dyno" thread.
before the wide use of the AFR 205 heads the only note worthy setups i recall are the TEA 2.5 ls6 and custom FMS cam, a few LGM combo's using ls6 heads and x2/x3 cams. i must say, that TEA/FMS combo had the most beautiful tq curve i'd ever seen; 350rwtq @ ~2800 and 400rwtq @ 3500
do you remember the port volumes on those heads brent, i seem to remember them around 231cc.
I'm so low
Stock heads, CC 212/218 .522/.529, SLP LTs. #'s are Dynojet SAE, complete mods and peak #s in sig.
